Old 09-15-2020, 04:40 PM   #1
Gezer
Gezer's Avatar
Thumbs down Carbon on plugs and piston tops
Would you suggest using Sea From cleaner to remove carbon?
Engine is a 51 EAB Flathead
Gezer is offline   Reply With Quote
Old 09-15-2020, 06:58 PM   #2
Ronnieroadster
Ronnieroadster's Avatar
Default Re: Carbon on plugs and piston tops
The piston tops on some modern production engines and many after market performance pistons have a coating applied to them {which is an expensive process} that acts as an additional heat barrier.
Carbon on the top of the piston is actually a good heat barrier if its not creating a carbon knock I would leave it alone.
Ronnieroadster
I use the F word a lot no not that word these words Flathead , Focus and Finish.
"Life Member of the Bonneville 200 MPH Club using a Ford Flathead block"
Owner , Builder and Driver of the First Ford Flathead bodied roadster to run 200 MPH Record run July 13, 2018 LTA timing association 200.921 from a standing start in one and a half miles burning gasoline.
Old 09-15-2020, 07:55 PM   #3
tubman
tubman's Avatar
I think we need a little more information from the O/P. Since a "51 EAB Flathead" is not a a factory combination, I think the O/P should provide us with a little more information about what he has.
Also, I fail to see what the reference to modern engines has any relevance here,
Old 09-16-2020, 09:52 PM   #4
cadillac512
cadillac512's Avatar
I believe Ronnie was likening the carbon buildup on a flathead piston and its attendant heat rejection qualities to the more recent application of modern coatings on pistons of later model engines.
Both serve a useful purpose as long as the carbon layer doesn't get too thick and cause interference problems or preignition.
Terry
"It don't take but country smarts to solve the problem" (Smokey Yunick)
'41 Merc Town Sedan / 260" 8CM engine
cadillac512 is offline   Reply With Quote
Old 09-17-2020, 08:40 AM   #5
40ford
40ford's Avatar
Can you not try a little water down the carb with motor rpms up?
40ford is offline   Reply With Quote
Old 09-17-2020, 02:22 PM   #6
drolston
drolston's Avatar
What 40ford said, except we always used kerosene. Dribble some into the carb at part throttle; as the engine sputters, jazz the throttle until it runs smoothly again. Repeat about 12 times.
Old 09-17-2020, 02:30 PM   #7
tubman
tubman's Avatar
To answer the O/P's question, a lot of folks I know (including myself) use Seafoam for this purpose. Just be prepared to really smoke up the area if you do it right. "drolston" has the technique about right, except the on last dose, we poured in enough to stall the engine out. Then let it sit for 10 minutes or so and restart it. That's when you get the billowing clouds of smoke. I don't know if kerosene works as well as Seafoam, as I have never used it. It certainly would be cheaper, though.
Old 09-17-2020, 03:57 PM   #8
B-O-B
B-O-B's Avatar
Back in the early 50s I ran kerosene in my A model. It ran pretty good just smoked a bit. Working for a dairy farmer for $20 & room & board didn't leave much & of course school. Had to milk the cows before school & clean out the stalls before school. No shower just change clothes & go. Must been really good perfume ha ha .
B-O-B is offline   Reply With Quote
