Old 11-22-2020, 01:08 PM   #1
Duke
Default 1929 Grill Mounts
Hi,
How is the grill held to the radiator?
Thanks
Duke is offline   Reply With Quote
Old 11-22-2020, 03:35 PM   #2
Synchro909
Synchro909's Avatar
Default Re: 1929 Grill Mounts
I assume you mean the stone guard. It is held on by a pair of "J" clips that hook into the holes in the shell where the headlight conduits emerge. Rubber stoppers hold it away from the shell.
Maybe someone will post a picture.
I'm part of the only ever generation with an analogue childhood and a digital adulthood.
Old 11-22-2020, 03:50 PM   #3
shew01
shew01's Avatar
shew01 is offline   Reply With Quote
Old 11-22-2020, 04:52 PM   #4
Duke
I was looking at the shell mounting. Thanks for the stone guard info, I hadn’t got there yet.
Old 11-22-2020, 05:11 PM   #5
Cape Codder
Cape Codder's Avatar
Two screws on each side. I have seen some covered by the material that is attached to the grill. Can be seen from inside of engine compartment.
Cape Codder is offline   Reply With Quote
