11-21-2020, 08:15 PM | #1 |
1941 super deluxe production number
I just bought a 41 super deluxe. The number stamped on the frame is 99 A
I 354387. Any idea what is going on? I need to get a title. It is an I not a 1 between the A and 3. Appreciate any help. |
11-21-2020, 08:55 PM | #2 |
Re: 1941 super deluxe production number
Are you aware of all the information available at VanPelts site? http://www.vanpeltsales.com/FH_web/f...ialnumbers.htm
Looks like a 41 Mercury serial number to me, but I'm no expert, just reading the chart. Last edited by JSeery; 11-21-2020 at 09:00 PM. |
11-21-2020, 10:42 PM | #3 |
It would help us to know your location, for instance NY doesn’t issue titles for any vehicle before 1973. 99A does look like a Mercury#. I once looked at a car from another state that had a cutout from another frame obviously brazed on the frame rail. Needless to say I passed on that car.
11-22-2020, 02:04 PM | #4 |
Deleted
I need an 01A 1453 Brkt Spare wheel hold down for my sedan delivery - PLEASE HELP Gotta love my '42 Sedan Delivery's - Now that I own the only two in New Zealand http://www.fordbarn.com/forum/album.php?albumid=580 Last edited by meric42; 11-22-2020 at 05:24 PM. |
11-22-2020, 05:15 PM | #5 |
Looks like 41 to me, 41 is 99A 257,101 to 99A 466,700.
11-23-2020, 03:59 PM | #6 | |
99A-650,280 thru 99A-I,4I2,709 Welcome to the 'Barn! DD Last edited by V8COOPMAN; 11-23-2020 at 04:15 PM. |
11-23-2020, 05:38 PM | #7 |
V8, so is the information posted on VanPelts site incorrect? I have not idea on these years, I was just going on what was in the charts there.
11-23-2020, 06:02 PM | #8 |
I believe his site shows correct info with regard to these number groups by year, except that his later numbers, including 1941 serials, show a figure "1", for which I took it upon myself to substitute the actual change to the letter "I" in lieu of a figure "1". I BELIEVE the actual change took place sometime in '38. Is that what you were referencing, J? DD
11-23-2020, 06:08 PM | #9 |
No, the serial number range for 41 Merc's.
11-23-2020, 06:11 PM | #10 |
I live in Wisconsin. The frame shows no signs of being changed.
11-23-2020, 06:38 PM | #11 |
DUHHHH.............! I'm a little slow sometimes. Now I see, and you're correct. That is a '41 Merc number. And there is a four inch difference in wheelbase lengths between Ford and Merc. Hmmm!
So, Mr. 41 ? ......what makes you think you have a Ford? Sure it ain't a Merc? Do you have any pictures? If you have pics but don't know how to post them here, are you capable of e-mailing some pics to either myself or JSeery? We can likely post them for you. DD |
11-23-2020, 06:46 PM | #12 |
Ya know, these cars were "given" their serial numbers when an "already-numbered" engine/trans assembly was dropped into the chassis at the assembly plant. I suppose it's humanly POSSIBLE that a Mercury unit was shipped out to an assembly plant in error, or maybe during time of shortage of available engine/trans units. I've seen more than one "weird", human error, documented serial number 'mistake' on early Corvettes, and have read about several more. Stuff happens sometimes! DD
11-24-2020, 09:22 AM | #13 |
The 1941 Ford could have a Mercury engine as the Mercury engine was an approved option in 1941. If the Mercury engine was installed at the factory into a Ford vehicle the Mercury serial number would have been stamped into the frame rail.
11-24-2020, 08:06 PM | #14 |
It is a ford, it has the 3 piece grille and says ford in the middle of the grille.
11-24-2020, 08:27 PM | #15 |
May be what 42fred posted.
11-24-2020, 08:59 PM | #16 |
Gotta be, 'cuz the frame number always originates with what is stamped on the trans/(engine) combination. DD
11-24-2020, 09:19 PM | #17 |
Sounds good to me. I'm going to try to register it and see what the DMV says. Thanks guys.
11-24-2020, 10:02 PM | #18 |
11-25-2020, 02:31 AM | #19 | |
Just so that YOU understand the Ford/Mercury engine production process, as I said before....when Ford assembled a new engine back then, it was mated to a transmission which was common to both Fords and Mercurys...SAME transmission! At that time, a serial number from an allotted sequence was stamped on that top, blank pad on the transmission's clutch housing....see picture below! If it was the 90 HP Ford engine, the transmission was stamped with a "Ford" serial number. If it was a 95 HP Mercury engine, the trans pad was stamped with a "Mercury" serial number. These engine/trans assemblies usually went into short-term stockpiles awaiting shipment to an automobile assembly plant. After arrival at assembly plant and installation into a chassis, that number stamped into the trans pad was hand-stamped into the passenger car chassis in three locations on the driver side frame rail, becoming the car's official serial number. The stock Ford engine in '41 was 221 cu. in. and was rated at 90 HP. The "OPTIONAL" Mercury engine was 239 cu. in. and was rated at 95 HP. The important info here is that cars were initially "serial-numbered" by the serial number originally stamped into the trans pad. Mercs had their own dedicated numbering sequence. Have this info fully-understood in your head so that you can rattle it off to the DMV clerk with authority! Good luck, and report back! IF your car happens to have the original transmission in it (with that "99A-" serial number stamped into it), I would take a picture of that with you to help back-up your documentation. DD ........ Last edited by V8COOPMAN; 11-25-2020 at 12:35 PM. |
11-25-2020, 09:41 PM | #20 |
Thanks for the info. I have the hood and fenders off so a picture won't help. It doesn't have the original engine or trans. It had a late model Ford engine and trans which I removed. The serial number had both stars and looks to have been hand stamped so I agree that the Merc engine would make sense.
