Old 11-20-2020, 07:53 PM   #1
harleycontracter
Default 31 Roadster wood floor pattern
Is there a source to get the pattern for a 31 Roadster front wood floor ?
harleycontracter is offline   Reply With Quote
Old 11-20-2020, 08:46 PM   #2
Bob C
Default Re: 31 Roadster wood floor pattern
Yes. http://www.stevewatrous.com/modelaford_p2.html
Old 11-21-2020, 04:37 AM   #3
ronn
I generally cut three sets at a time and have them on hand.
always having a project show up
Old 11-21-2020, 07:11 AM   #4
harleycontracter
What do you get for a set or would you sell me the pattern?
Old 11-21-2020, 12:05 PM   #5
ronn
dont sell them_ I use them
they are for sale on ebay for around 70 a set.
you can stop by and trace a set of mine if near NJ
Old 11-21-2020, 01:46 PM   #6
harleycontracter
I'll check Ebay
Old 11-21-2020, 02:26 PM   #7
Oldbluoval
Oldbluoval's Avatar
It’s been ages since I worked on roadster
How are those pieces different than others?
I understand left brake etc
Are they the same as all 30-31 model a??
It’s not that easy to find solid core quality plywood....at least for me it is these days
Old 11-22-2020, 05:23 PM   #8
harleycontracter
I think they are the same on all 30/31 ???? My E Brake is to the right of the shifter
Old 11-22-2020, 06:45 PM   #9
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
The biggest difference is most commercially available reproduction floorboards are the incorrect thickness.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 11-23-2020, 06:23 AM   #10
Oldbluoval
Oldbluoval's Avatar
Looks like print shows 11/16.....that ain’t out there
Old 11-23-2020, 03:25 PM   #11
BRENT in 10-uh-C
This is where a drum sander comes in handy. The ¾" Plywood has a nominal thickness ²³⁄₃₂" which is 0.719", and the ¹¹⁄₁₆" Plywood should have a finish size of around 0.687". That means if we remove about 15-thousands off each side of the ¾" Plywood, then we have the proper thickness.
Where I am struggling is trying to make ½" (0.500") Plywood for Station Wagon bodies. The print calls for a ⅜" birch core with two ¹⁄₁₆" birch veneers laminated.
BRENT in 10-uh-C
