Old 06-28-2020, 06:49 AM   #1
lrjones
Default New Tire Recommendation
I am thinking about replacing my 20 year old Firestone tires on my 31 coupe and looking for the latest recommendations. Tires are not worn out, just old. I would be interested to find out any of your recent experiences purchasing tires. Radials? New tubes? Thank you in advance for any advice.
lrjones is offline   Reply With Quote
Old 06-28-2020, 08:35 AM   #2
1931 flamingo
1931 flamingo's Avatar
Default Re: New Tire Recommendation
Lots of tire reviews here. Many go with the lookalike radials. Try doing a search.
Paul in CT
Old 06-28-2020, 10:48 AM   #3
chrs1961815
chrs1961815's Avatar
I just replaced mine with a new set of goodyear bias tires from coker. They feel great and look great.
"The more things change, the more they stay the same."
chrs1961815 is offline   Reply With Quote
Old 06-28-2020, 11:06 AM   #4
Russ/40
Russ/40's Avatar
Since you did not wear out your existing tires after all those years, durability is not as important. If your not concerned about judging, I would suggest a very reasonable choice. The Lucas tires are only $100 a piece. I really like mine. They ride nice and they didn't even need to be balanced. Easy to mount yourself when you use the trash bag trick. Really a decent tire and thrifty.
Brattons sells the best tubes!
Old 06-28-2020, 11:37 AM   #5
Ruth
I agree with Russ and I really like the looks of the Lucas Tire which is important to me. Some of the more expensive tires just don't apeal to me.
Ruth
Old 06-28-2020, 12:18 PM   #6
Ernie Vitucci
Agree with Russ...I have run Lucas tires for six or seven years...Ernie in Arizona
Old 06-28-2020, 01:20 PM   #7
SoCal_Alden
SoCal_Alden's Avatar
My truck had been running on Brazilian made Goodyears from 1978 when I brought it home. I like the diamond tread pattern, but the price of new Goodyears is prohibitive so I opted for European Classics which have the diamond tread for about the same price as the Lucas tires. While at it, had the wheels powder-coated and found a set of Delrin coated lug nut sockets at HF to keep from dinging up the wheels.
SoCal_Alden is offline   Reply With Quote
Old 06-28-2020, 04:01 PM   #8
McMimmcs
McMimmcs's Avatar
I bought a set of Goodyears and I am very satisfied. Check all suppliers as some offer free shipping.
Old 06-28-2020, 04:15 PM   #9
ricconhan
ricconhan's Avatar
Okay, someone fill me in on "The trash bag trick" please.
ricconhan is offline   Reply With Quote
Old 06-28-2020, 04:58 PM   #10
d.
try the "search" option...lots of info on this has been posted many times already.
d. is offline   Reply With Quote
Old 06-28-2020, 11:54 PM   #11
Russ/40
Russ/40's Avatar
Basically, you lay a large garbage bag over the wheel, as it lays on a carpet floor. The slippery nature of the bag allows you to slip the tire over the rim by hand with no tools.
Old 06-29-2020, 02:11 AM   #12
Richard in Anaheim CA
Richard in Anaheim CA's Avatar
I go for the best, Goodyear from Kelsey Tire the manufacturer. They are located in Missouri
Richard
Anaheim CA
Richard in Anaheim CA is offline   Reply With Quote
Old 06-29-2020, 06:43 AM   #13
RRW
Send a message via Yahoo to RRW
Very pleased with my Lucas tires and tubes ordered directly from Lucas.
RRW is offline   Reply With Quote
Old 06-29-2020, 06:49 AM   #14
old31
I went with Cokers WW 19" radials, new tubes, metal stems and love them.
old31 is offline   Reply With Quote
Old 06-30-2020, 06:30 AM   #15
lrjones
Thank you all for your comments.
Old 06-30-2020, 03:37 PM   #16
TLR
TLR's Avatar
Been running the american classic radial tires with the proper tubes from Coker. Smoothed out the ride and have not had any issues so far. I mounted with tire irons and plenty of talc per Coker and they were easy to mount. Set them at 32psi and check them every time I take a ride.
TLR is offline   Reply With Quote
Old 07-02-2020, 03:33 PM   #17
ronn
summit has free shipping on 99. purchase or higher. they are also offering some percentage off, depending how much you spend. not sure if that applies to tires though..........
Old 07-03-2020, 11:28 AM   #18
Jim M
Jim M's Avatar
I am another happy Lucas customer. The garbage bag trick works fine!
Jim M is offline   Reply With Quote
Old 07-03-2020, 08:32 PM   #19
Russ/40
Russ/40's Avatar
Do us all a favor, and tell us what choice you made, whatever it is. Just curious.
Old 07-03-2020, 10:49 PM   #20
Cpuckett
Please do!!
Cpuckett is offline   Reply With Quote
