Old 09-16-2020, 10:39 PM   #1
1crosscut
1crosscut's Avatar
Default Mixing lifters
This evening I was working on lapping in some original style valves and a thought ran across my mind. A person has plenty of time to think while lapping in valves...
So I did a search and didn't find anything on it and I thought I would throw it out there for comment.
What would be the ramifications of using one, two or more adjustable lifters in and engine that has original style lifters and valves?
Dave / Lincoln Nebraska
1crosscut is offline   Reply With Quote
Old 09-16-2020, 11:40 PM   #2
Russ/40
Russ/40's Avatar
Default Re: Mixing lifters
If all lifters were properly set it would be fine.
Russ/40 is offline   Reply With Quote
Old 09-16-2020, 11:50 PM   #3
McMimmcs
McMimmcs's Avatar
why would you possibly want to ?
McMimmcs is offline   Reply With Quote
Old 09-17-2020, 07:42 AM   #4
Licensed to kill
Licensed to kill's Avatar
If you have a couple valves that require adjusting, just grind those valves to the proper clearance. If you go to the trouble of removing the can cam to change out those lifters, change them all. I don't see any reason why you can't run some of each just don't see the point either
Licensed to kill is offline   Reply With Quote
Old 09-17-2020, 08:27 AM   #5
Jack Shaft
No ramifications,I would use at least 4,do the exhaust valves,they benefit the most from proper adjustment.The longer they are on the seat the cooler they get.
When your cam is out swap it for a B regrind,the best 100 bucks you ever spent for engine performance..
Jack Shaft is offline   Reply With Quote
Old 09-17-2020, 11:18 AM   #6
Jim Brierley
Absolutely no problems. All mechanical things are stupid, #1 doesn't know or care what #2 is doing!
Jim Brierley is offline   Reply With Quote
Old 09-17-2020, 12:42 PM   #7
1crosscut
1crosscut's Avatar
I'm not saying that I want to I'm only throwing it out there for thought. However there are a lot of folks out there that may not necessarily have the money to do a full swap and this looks like it would be a viable option.
Old 09-17-2020, 02:00 PM   #8
Pete
Pete's Avatar
What would be the ramifications of using one, two or more adjustable lifters in an engine that has original style lifters and valves?
Just be sure they are new or been refaced.
It s not recommended to put used lifters on a cam they have not been running on originally.
Thread Tools
Display Modes
