Old 10-14-2020, 04:18 PM   #1
Ramjet47
Ramjet47's Avatar
Default 11-A Distributor Thread Size
I have a stripped thread on a distributor I am overhauling. What is the thread size of the vacuum connection?
Ramjet47 is offline   Reply With Quote
Old 10-14-2020, 04:23 PM   #2
Mart
Mart's Avatar
Default Re: 11-A Distributor Thread Size
3/8 -24 UNF. 99% sure can anyone confirm?
Old 10-15-2020, 07:29 AM   #3
rockfla
rockfla's Avatar
NO expert BUT being a brass fitting/tube wouldn't it be a "NPT" or a National Pipe Thread because "Machine" threads do not "seal" so you couldn't seal the "vacuum" with a machine thread!!! MY "guess" would be a 1/8th NPT or 1/8 National Tapered Pipe Thread!!! AS I said....MY GUESS
Old 10-15-2020, 07:41 AM   #4
Mart
Mart's Avatar
Rock, no, mate, I just went and checked, it is the fitting for a 3/16 tube, which is 3/8-24 UNF.
A 3/8-24 tap screws in nicely but a 1/8 NPT barely starts and goes tight straight away.
It was late when I posted last night, but was able to do a physical check today.
The nut has a tapered end which bites into the pipe.
Mart.
Old 10-15-2020, 07:43 AM   #5
Mart
Mart's Avatar
If you've stripped it, you could go 1/8 NPT and use an adaptor to get back to 3/16 tube.
Old 10-15-2020, 07:45 AM   #6
rockfla
rockfla's Avatar
Damn bad day IF you don't "Learn something" everyday!!!! Good day, today!!! Thanks Mart
Old 10-15-2020, 07:51 AM   #7
deuce lover
deuce lover's Avatar
Here is the fitting it takes I think.3/8 24 as Mart said
Old 10-15-2020, 08:01 AM   #8
JM 35 Sedan
JM 35 Sedan's Avatar
The sealing required at this fitting would not be accomplished at/or by the 3/8-24 threads.
John
Old 10-15-2020, 08:28 AM   #9
JSeery
JSeery's Avatar
Mart, wouldn't any adapter require a provision to seal the original 3/16 fitting. I think it is going to require some measure to repair the existing threads or switching to some other method to seal the 3/16 tube with the adapter. Unless there is an adapter that provides the seat required for the original fitting.
Old 10-15-2020, 10:51 AM   #10
rotorwrench
rotorwrench's Avatar
That was Ford's original compression fitting that was used clear up into the 60s at least.
Old 10-15-2020, 11:42 AM   #11
tubman
tubman's Avatar
I've always known them as "Ford Nuts".
Old 10-15-2020, 11:59 AM   #12
JSeery
JSeery's Avatar
Ya, I would really think hard about any attempt to tap it out to a different size, could really open up a can of worms.
Old 10-15-2020, 12:55 PM   #13
supereal
supereal's Avatar
Ford used a lot of unusual thread sizes and pitches. At our shop we aways save any "left over" nuts and bolts. We have several coffee cans of them, and have been glad we did.
supereal is offline   Reply With Quote
Old 11-08-2020, 04:15 PM   #14
Ramjet47
Ramjet47's Avatar
Thank you to all who replied. I have now re cut the thread back to 3/8”x24 UNF, not perfect but with thread sealant it will be OK. Best regards Roger.
