Old 07-12-2020, 04:10 PM   #1
Step-down
Step-down's Avatar
Default Off shore adjustable lifters
I know we have beat this to death on other threads but thought I would post couple pictures of how these off shore lifters fail .
File Type: jpg CD64D45F-E38D-4EC1-AAD2-BAB49DF6BCE6.jpg (32.2 KB, 233 views)
File Type: jpg 865A0B50-CC8A-4C1B-A6F8-E48C6CE75C49.jpg (28.2 KB, 245 views)
File Type: jpeg BAF829A4-A4FE-4EE0-9BAC-06AD592B1C3E.jpeg (20.5 KB, 254 views)
"I can't cry as long as I know the Lord has risen "
Step-down is offline   Reply With Quote
Old 07-12-2020, 05:06 PM   #2
Kube
Kube's Avatar
Default Re: Off shore adjustable lifters
I think it's nice of you to remind folks the common issues with these. Some folks may not have seen previous threads to this regard.
I am fortunate to have access to a hardness (Rockwell) tester.
The recent set I'd tested (form Red's) found three of sixteen very soft (junk) . They would not have held up for very long whatsoever.
Kube is online now   Reply With Quote
Old 07-12-2020, 05:20 PM   #3
51504bat
51504bat's Avatar
What did Red's say?
Old 07-12-2020, 05:55 PM   #4
GOSFAST
GOSFAST's Avatar
It's specifically for this reason we use/sell ONLY the original Johnson tappets, today they come from "Topline", the same mfr still as the old days!
I have trouble keeping these in stock all the time we sell so many.
I would just add a bit more info here while we're on the lifter subject. It's extremely important to use the proper break-in lube, we use ONLY "moly" lube here, on the lobes and the lifter faces. After the initial break-in it's also necessary to run some higher-end oil, not the kind you find in the typical Walmart type stores?
Thanks, Gary in N.Y.
P.S. Here's a few shots of the lifters and the lube. We just recently began supplying a small container of the lube with every 16 lifters!
GOSFAST is offline   Reply With Quote
Old 07-12-2020, 05:56 PM   #5
Step-down
Step-down's Avatar
I have to replace these lifters so the question is who’s .
Old 07-12-2020, 06:26 PM   #6
earlyride
earlyride's Avatar
Is there any damage to the cam lobes with the effected lifters?
earlyride is offline   Reply With Quote
Old 07-12-2020, 06:46 PM   #7
Talkwrench
Talkwrench's Avatar
Looks like you missed Gary's post by a minute.. as above ^^^^
Old 07-12-2020, 07:10 PM   #8
Kube
Kube's Avatar
These (the ones that 3 of 16 were dead soft) were Johnson brand from red's.
Do you test the ones you use?
Old 07-12-2020, 08:06 PM   #9
GOSFAST
GOSFAST's Avatar
Hi Kub', would have to contact Paul at "Topline" and ask if they happen to supply Reds with lifters?? I can state with certainty that both Comp Cams and Isky get their Flathead lifters from "Topline".
Haven't had one single "bad" lifter so far from "Topline" so no real reason to check them. First time I have an issue that would change things really quick!
P.S. I did just check Reds website, really doesn't state original "Johnson" lifters, it does however say Johnson "style" lifters . We've been warning customers for years now about buying/using Johnson "style" lifters. The few I've had come in here (supplied by customers) were definitely "off-shore".
Old 07-13-2020, 10:23 AM   #10
Ol' Ron
Ol' Ron's Avatar
I used to buy my lifters from Collens & Lery in BP conn. One day I went into the shop and ordered a set. The counterman said"That will be 20 dollars" I said" at this rate they'll be 50 dollars before you know it". They had bee $12.50 set
I believe gary's lifters are the same as the originals, the only difference is the value of the money????????
Old 07-13-2020, 10:36 AM   #11
19Fordy
19Fordy's Avatar
GOSFAST: I still have the old box my original Johnson lifters came in in 1970. Two wrenches
were included. Next time you order lifters from "Topline" please inquire as to whether they were formerly "Wolverine". Just curious. Would be neat to know. Is "Topline" located at the old Wolverine address or city?
Old 07-13-2020, 11:10 AM   #12
35fordtn
35fordtn's Avatar
Why even fool with adjustables? Ford didn't use them, and original lifters rarely fail and weight a lot less.
For me I can grind valves for non adjustables much quicker than I can adjust those pesky adjustables.
Old 07-13-2020, 11:38 AM   #13
Step-down
Step-down's Avatar
No damage to cam (Max 1) check valve spring pressure seems good.
Old 07-13-2020, 11:45 AM   #14
GOSFAST
GOSFAST's Avatar
Back in the '80's Wolverine owned what is now "Topline", we had a "WD" with them for years. The entire conglomerate was owned by "The Sherlin Corp", at one point Crane Cams owned it all also!
We became good friends with Harry Krummery, the engineer at the Blue-Racer division of Wolverine! It's all a really long story!
P.S. I put a couple shots below here of the catalog showing the Flathead lifter number, VT-2032, even back then we were buying the lifters by the trays, 92 to a tray, and the original "Johnson" tappet catalog! Hope you can make it out! These lifters back in 1994 cost us $3.70/ea. I still have much inventory on the shelf from them including the aluminum cam gears, part #TG-2702.
Old 07-13-2020, 01:48 PM   #15
Ronnieroadster
Ronnieroadster's Avatar
Are you sure those solid body lifters are off shore? Reason I ask the only off shore lifters I have seen are hollow copies of the Johnson lifter. The solid lifters I recall were US made. Anyone else know for sure if the solid lifters are offshore?
Ronnieroadster
I use the F word a lot no not that word these words Flathead , Focus and Finish.
"Life Member of the Bonneville 200 MPH Club using a Ford Flathead block"
Owner , Builder, Driver of the First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 in one and a half miles burning gasoline.
First ever gas burning Ford flathead powered roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH
Old 07-13-2020, 02:05 PM   #16
19Fordy
19Fordy's Avatar
GOESFAST, Thanks so much for taking the time and effort to answer my question. I feel better now, knowing Topline is an excellent replacement.
I don't remember if the original "Johnsons" were flat or did they have a slight crown.
Are the Topline lifters flat or crowned? I do still have an old set of Johnsons lifters that are ground with a slight radius. Is that good, bad or desirable only with certain cams?
Thanks, Jim in FL
Old 07-13-2020, 02:25 PM   #17
Step-down
Step-down's Avatar
Ronnieroadster
Don’t know either way who’s lifters they are . When I saw the lifter face and after checking spring tension I draw to a fast conclusion “My bad “
I don’t see any sign of any wear on the cam lobe .
This lifters is flat on top , I thought they should have a slight dome , doesn’t that create The lifter to spin or is it the cam lobe grind that make the lifter spin .
Hell I don’t know just a old Harley Guy having fun with these Flathead
Old 07-13-2020, 02:49 PM   #18
GOSFAST
GOSFAST's Avatar
Thanks, Jim in FL
They've always had the "crown" on the lifter face, it helps with two things, first, it helps to keep the lifters "spinning" for a constant oil supply and second, it helps keep the cam running into the unit. Sort of "threading" it into the block!
They also have the a radius on the adjusting nuts as well where they contact the valve stem. This is most likely done to keep the point-of-contact between the stems and the adjusting nuts to a minimum, makes it less important where "alignment" would be an issue??
P.S. On side note almost all cam lobes are ground with a taper to correspond with the lifter radius! Again, this keeps everything "spinning" so to speak! The only lifters (I believe) without a radius were used on the old "Nailheads"?? One of the cam guys up here may know for sure? This photo from Isky's catalog may help understand what's occurring?
Old 07-13-2020, 02:54 PM   #19
petehoovie
petehoovie's Avatar
Old 07-13-2020, 03:34 PM   #20
Ronnieroadster
Ronnieroadster
Yes your correct the lifters do have a slight crown/radius to them. If you hold a set of new lifters face to face with light behind them you can see the radius. The good quality original lifters from Johnson even if used will have the radius. However considering the reduction and eventually the elimination of Zinc additives in most brands of engine oils since the 80's lifter wear like the set you have will happen. Extremely worn lifters will be flat when held face to face.
Ronnieroadster
