Old 10-18-2012, 08:58 AM   #1
rosenkranswa
rosenkranswa's Avatar
Default Quick question
Our '42 Sedan was dead this morning, no lights, no gauge movement, no cranking, nothing and wouldn't take a charge from the trickle charger. I'm assuming shot battery. Its gotten cold here and she hadn't been started in a few weeks.
Can I do a quick jump with a 12v jump starter without frying anything? Its almost impossible to reach the battery in my shed and I'll have to push her out otherwise to do the replacement.
Wayne @ Barb
Malvern
'19 T Speedster
'26 T Touring
'29 A Roadster
'30 AA Stakebed
'30 A Pickup
'30 A Town Sedan
'31 A Station Wagon
'38 Columbia Girls bike (WWII)
'40 Elgin Boys bike (WWII)
'42 Super Deluxe Tudor
'42 Willys MB Jeep
'43 Willys MBT Trailer
'43 M3A4 Hand Cart
'43 Harley Davidson 42WLA with sidecar
rosenkranswa is offline   Reply With Quote
Old 10-18-2012, 09:09 AM   #2
Bruce Lancaster
Default Re: Quick question
It'll be fine. I'd be sure lights, radio, anything but ignition switch is off to avoid all risk.
Bruce Lancaster is offline   Reply With Quote
Old 10-18-2012, 09:12 AM   #3
flatheadernie
DISCONECT batt or jump direct to starter to test, could be u need to clean batt connection?? ernie n tx
flatheadernie is offline   Reply With Quote
Old 10-18-2012, 09:21 AM   #4
rosenkranswa
Thanks guys! Just wanted to make sure before I maybe did something stupid...
Wayne @ Barb
Malvern
'19 T Speedster
'26 T Touring
'29 A Roadster
'30 AA Stakebed
'30 A Pickup
'30 A Town Sedan
'31 A Station Wagon
'42 Willys MB Jeep
'43 M3A4 Hand Cart
Old 10-18-2012, 09:27 AM   #5
Big_Guys_baby
Dumb question: how do you deal with polarity when jumping from 12V neg
Ground to 6V pos ground?
Big_Guys_baby is offline   Reply With Quote
Old 10-18-2012, 09:34 AM   #6
Mountaindoc
Mountaindoc's Avatar
It's not a dumb question. Hook the positive to the positive on the battery and the negative to the negative post on the battery. The easiest way to remember that is you're essentially replacing the dead battery for the good battery.
BTW, you can buy a battery charger at Tractor Supply, Walmart, and pretty much any auto part store that has a 6 volt charge/boost setting. The one I'm thinking about is manufactured by "Schumacher". I'd definitely get one before this happens the next time. It's not a healthy thing to keep using a 12 volt battery to boost a 6 volt car.
Mountaindoc is offline   Reply With Quote
Old 10-18-2012, 12:46 PM   #7
rosenkranswa
Success! No problem on the jump and disconnnected immediately after she started. Now is taking a charge as well - may have been bad cable connections.
Wayne @ Barb
Malvern
'19 T Speedster
'26 T Touring
'29 A Roadster
'30 AA Stakebed
'30 A Pickup
'30 A Town Sedan
'31 A Station Wagon
'42 Willys MB Jeep
'43 M3A4 Hand Cart
Old 10-18-2012, 07:56 PM   #8
Ken Crans
Ken Crans's Avatar
Make sure you got good size battery cables and use an Optima if replacing.
Ken Crans is offline   Reply With Quote
Old 10-19-2012, 09:20 AM   #9
rosenkranswa
The cables are the appropriate stock cables. I've not had good luck with the Optimas, may be the only person that has. Had to replace two in my Model A's recently.
Disconnected the cables and ran a cleaner brush through them, then some dialectric grease to reassemble. Everything seems fine now. Interestingly, I had the same problem with my Model T that morning, I knew I was on borrowed time with that battery though.
Wayne @ Barb
Malvern
'19 T Speedster
'26 T Touring
'29 A Roadster
'30 AA Stakebed
'30 A Pickup
'30 A Town Sedan
'31 A Station Wagon
'42 Willys MB Jeep
'43 M3A4 Hand Cart
