Old 02-01-2020, 04:56 PM   #1
chrs1961815
chrs1961815's Avatar
Default Odd Water Pump?
Got this in a lot of parts recently. The housing is normal but the shaft and impeller are quite different. The impeller is a completely different design with 4 blades and under it is a spring. Anybody ever see one like this before?
"The more things change, the more they stay the same."
chrs1961815 is offline   Reply With Quote
Old 02-01-2020, 05:10 PM   #2
Purdy Swoft
Purdy Swoft's Avatar
Default Re: Odd Water Pump?
I have some that I got in a collection . They must have been after market . I have used one and it didn't leak , even though no packing or packing nut was used on these pumps .
Old 02-01-2020, 06:44 PM   #3
David R.
Guessing by the spring under the impeller it may have a ceramic seal.
David R. is offline   Reply With Quote
Old 02-01-2020, 06:53 PM   #4
chrs1961815
I wonder if they move more coolant as the impeller is larger and has four blades versus the stock three.
Old 02-01-2020, 07:33 PM   #5
redmodelt
redmodelt's Avatar
I am pretty sure that is a Ford replacement using the later V8 type impeller. Tom has several sitting around the shop.
Old 02-01-2020, 07:47 PM   #6
Joe K
Joe K's Avatar
Aftermarket replacement - may be a Ford replacement after Ford's development of the V8 pump (which the impeller resembles greatly.)
IIRC, the front bearing housing is "small" and contains only a sleeve type bearing lubricated by a grease zerk alemite style - which leads me to believe non-Ford source. Ford tried a sleeve bearing at this location for perhaps a month in 1928 and found it unsatisfactory.
They're around muchly and pricing is cheap. But replacement parts are not available and were probably not "in the day" either as one could buy the entire pump for small money.
Here's the expensive one on Ebay. https://www.ebay.com/itm/1928-1929-1...MAAOSwBsNbcbad There are two others of this kind listed at less than half the price.
Joe K
Shudda kept the horse.
Joe K is offline   Reply With Quote
Old 02-01-2020, 08:05 PM   #7
aford193031
aford193031's Avatar
In 2010 at Hersey, I saw several rebuild kits for sale. He was selling the kits as no’s model a water pump kits.
aford193031 is offline   Reply With Quote
