12-04-2019, 07:06 PM | #1 |
Can you help with this? Tool related
Can anyone tell me where to find the "mandrel" for this type roloc?
12-04-2019, 09:44 PM | #2 |
Re: Can you help with this? Tool related
they were made by 3M years ago. maybe they are still available from them. I used to use them a lot with good results
12-05-2019, 01:06 AM | #3 |
I have acquired a large quantity of the older type, but have not been able to find a mandrel to be able to use them.
12-05-2019, 01:06 AM | #4 |
Google “3M Roloc Mandrel”. Came up with a lot of hits.
Back when I was still working, I bought them from industrial hardware store or aircraft supply houses.
12-05-2019, 12:56 PM | #5 |
12-05-2019, 01:14 PM | #6 |
12-05-2019, 01:55 PM | #7 | ||
1929 Coupe 1930 Coupe 1935 Ford 5 window coupe |
12-05-2019, 03:45 PM | #8 | |
You have to have this to make it work correctly. https://www.grainger.com/product/52J...QYCSABEgLXwfD_ |
12-05-2019, 04:59 PM | #9 |
OK, how about this. https://www.amazon.com/Medium-3M-Rol...JEW39S79D254YG
12-05-2019, 05:42 PM | #10 | |
12-05-2019, 06:40 PM | #11 |
Bob C, I think that is it. Apparently there are two or three sizes for diff size discs. Also, i don't see any way to back up the discs. Bob C's photo might be for that, but it doesn't look like it to me. RogerKB1936, what do you think of the ones in post #9. Is that the correct rear pad?
12-05-2019, 06:57 PM | #12 |
Bob and Russ..
That's what I use. I have 2 sizes, for the different size pads. I use 2" and 3",...the English grinding flapper wheels work on them.. Dudley |
12-05-2019, 07:46 PM | #13 |
Hi. Guys , yes the picture of the backing pads is right, I have been using them for years, they will thread right onto the threaded mandrel that is threaded into my Dotco angle grinder . I cut down one of the backing pads to 3/4" for those tight spots. Just cut the disc to about 1""The discs are available in several grits,and are good quality.Make sure you use safety glasses. Cheers
12-06-2019, 01:27 AM | #14 |
12-06-2019, 01:41 AM | #15 |
12-06-2019, 10:43 AM | #16 |
I have never seen that type
12-06-2019, 12:00 PM | #17 |
12-06-2019, 12:00 PM | #18 |
Geez,....You live right down the street from S.D. There has to be an industrial
supply house the service's machine shops! You need to walk in with some of pads so BOTH of you know what you have. I have both styles too attach the different types of pads.. Dudley |
12-06-2019, 04:40 PM | #19 |
The older style of disc had a 3tab attach to the adapter. The discs were known to come loose and zoom away ,very dangerous. If you still have the old style I would not use them .
12-08-2019, 01:21 AM | #20 |
Try MSC Direct, page 1025 & 1026 of their on line catalog.
