Old 03-05-2016, 11:34 AM   #1
Jay in Mass
Default 57 Ford ball joints
Instead of using the off shore bubble gum junk, I'm told that some later year Ford ball joints fit the 57 Fords with a very slight modification. Does anyone have some information on this like what year ball joints and what is the modification?? Thanks for any and all replies. Jay
Jay in Mass is offline   Reply With Quote
Old 03-07-2016, 12:37 PM   #2
bobss396
bobss396's Avatar
Default Re: 57 Ford ball joints
PST has a pretty good assortment of parts for the '57. Check newer years to see what is common between them. From my experience, lots of front end parts were common through 1964. Moog makes one ball joint, forget which one.. either the upper or lower.
http://catalog.p-s-t.com/index.php?c...econfigID=6455
bobss396 is offline   Reply With Quote
Old 03-10-2016, 05:34 PM   #3
Jay in Mass
bobss396....Thank you for that information
Old 03-10-2016, 09:13 PM   #4
bobss396
bobss396's Avatar
I got most of my front end parts elsewhere... questionable quality. Some made in India as well. My OG Ford castle nuts were better than the ones I was supplied with and reused them.
Old 03-11-2016, 01:19 AM   #5
JeffB2
JeffB2's Avatar
These older Fords had very sturdy ball joints always do a good lube before you check play in your old ones.
JeffB2 is offline   Reply With Quote
Old 03-11-2016, 03:22 PM   #6
bobss396
bobss396's Avatar
True dat... the '57 - '64 front ends are very similar and I've replaced more upper a-arm bushings in these cars than anything. Tie rods a few here and there, upper ball joints never. Most problems come from parts not being greased. The manuals call for a front-end lube every 1000 miles.
Old 03-11-2016, 07:14 PM   #7
darrell
the bottom ball joints usually went when you got close to 100.000.i remember driving a 61 merc and down she went at about 60mph rubber burning and wore the side of the tire to the canvas.the worst part was they were riveted on.i spent 2 hours at the side of the road with a dull chisel and hammer.
darrell is offline   Reply With Quote
Old 03-11-2016, 09:41 PM   #8
paul2748
paul2748's Avatar
The sad part is that anything you buy now is probably import junk.
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 03-12-2016, 06:14 AM   #9
Jay in Mass
The good thing is that I don't need a set of upper ball joints for my 57 right now. My original ones are still nice and tight. I was just looking to see what would fit when I do need them. Seems like up to 64 Ford is pretty much a bolt in and the 65 up need slight massaging. Thanks for the comments. Jay
Old 03-30-2016, 05:42 PM   #10
mobileparts
I have AMERICAN made -- MOOG Upper & American made Lower
for the 1957 - 1964 Ford Full size application....
Control Arm Bushings for all the years also....
Feel free to call me -- Craig -- 516 - 485 - 1935 ... New York...
mobileparts is offline   Reply With Quote
Old 03-31-2016, 08:03 AM   #11
bobss396
bobss396's Avatar
This guy is the real deal, if you need something try him first.
