Old 01-10-2024, 01:48 PM   #1
Bustingear
Default Part ID Help
I have about 6 items that have been floating around my garage that i believe are either model A or T ford and i am trying to pinpoint year make and model for each. Thanks for any help.
Bustingear is offline   Reply With Quote
Old 01-10-2024, 09:44 PM   #2
stevests
stevests's Avatar
Default Re: Part ID Help
The last photo is of the remnants of an accessory rear shock off a Model T.
stevests is offline   Reply With Quote
Old 01-10-2024, 11:53 PM   #3
J Franklin
J Franklin's Avatar
Most are from an early Model A.
Old 01-11-2024, 08:10 AM   #4
Bustingear
thanks looking for more info
Old 01-11-2024, 11:38 AM   #5
Will N
Will N's Avatar
The first two are from an early 1928 Model A that has the complicated multi piece brake actuating cross shaft.
Will N is offline   Reply With Quote
Old 01-11-2024, 12:33 PM   #6
redmodelt
redmodelt's Avatar
Bottom row: No clue on the first piece, one of those I have seen it before but don't recall. Middle: Ford Model A flywheel housing shield. End: part of rear aftermarket Ford Model T shock, missing the coil spring.
