Old 11-16-2023, 12:41 PM   #1
steve hackel
steve hackel's Avatar
Default 1933 pick up firewall removal
Can the firewall of a 33 pick up truck, with a 4 cylinder motor, be removed - or is it welded in place like the model A's were? Trying to resolve old issues with a heater, heater hoses, way too many extra holes etc. Figured I'd ask the "go to" guys for the answer before blindly attempting it.
Thanks, Steve Hackel
steve hackel is offline   Reply With Quote
Old 11-16-2023, 12:53 PM   #2
deuce lover
deuce lover's Avatar
Default Re: 1933 pick up firewall removal
Maybe spot welded in places and riveted.You need to brace the cowl if you do that.
Old 11-16-2023, 02:08 PM   #3
DavidG
DavidG's Avatar
Definitely spot welded in place. The 1932 models are the only post-Model T ford vehicles with detachable firewalls.
Old 11-16-2023, 03:30 PM   #4
FlatheadTed
FlatheadTed's Avatar
I would try to weld them up depends what else is wrong with it .Ted
http://www.flatheadted.com
Flathead Ted brake Floaters ,
Old 11-16-2023, 06:00 PM   #5
fordv8j
fordv8j's Avatar
I welded up 32extra holes in the firewall of our 38 conv. made plugs for the big ones, just welded small ones...much easier than removing firewall
fordv8j is offline   Reply With Quote
Old 11-16-2023, 06:08 PM   #6
Zeke3
Zeke3's Avatar
I hacked up the firewall in my 1937 back in ‘67 to fit a 289 in it. When it came time to repair the damage and all the holes from a previous heater install, I cut out the center of the firewall and patched with a replacement from a donor firewall. You might be able to see the repair in my avatar.
Zeke3 is offline   Reply With Quote
Old 11-16-2023, 09:45 PM   #7
al's28/33
al's28/33's Avatar
Firewall is all part of the cab, cowl, top and rear panel.
mine was a swiss cheese too but I just found grommet hole plugs of various sizes to snap in place and covered with speed shop decals, Pennzoil and gasoline stickers.
1928 "A" Phaeton (mid year with many early features)
1933 "V8" Closed-Cab Pickup Truck
(originally a Model B, 4 Cylinder dating to May, 1933)
Old 11-17-2023, 12:47 AM   #8
DavidG
DavidG's Avatar
Late '32 through '34 closed cabs have detachable roofs. They are not spot welded in place.
Old 11-17-2023, 09:46 AM   #9
itslow
itslow's Avatar
IIRC, the firewall + cowl structure isn't welded to the floor - only riveted - as is the rear door jamb + rear panel structure, making it relatively simple (albeit time consuming) to knock-down a cab.
Mike
Wanted:
- '32-34 Open Cab Pickup (RPU) parts and documents/articles/info
- ARDUN parts
itslow is offline   Reply With Quote
