Old 12-05-2020, 10:08 AM   #1
Mike Barrett
Default rear wheel stud installation
I am replacing a rear wheel stud on my 1930. There is a little triangle shaped guide that fits into a notch in the brake drum. What is the best way to set the stud in place ? Does it have to be machine pressed or will a hammer and brass punch work ? Thanks in advance.
Mike Barrett is offline   Reply With Quote
Old 12-05-2020, 10:13 AM   #2
jwmckenzie
Default Re: rear wheel stud installation
They have to be swedged. 20 ton, at least, press. Here is one thread, there are likely others.
https://www.fordbarn.com/forum/showt...ghlight=Swedge
jwmckenzie is offline   Reply With Quote
Old 12-05-2020, 11:56 AM   #3
Bob C
Good information on Vince's site. http://www.fordgarage.com/pages/swaging.htm
Old 12-08-2020, 09:36 PM   #4
Al 29Tudor
Al 29Tudor's Avatar
Not all machine shope can do this swedging correctly. I had one shop try and his press was not strong enough. Then another tried and i had to go back so he could try again. Finally i went to have the drums turned and the studs were. That machinest said you need a 40 ton press to swedg thoes studs.
Al
Al 29Tudor is offline   Reply With Quote
Old 12-09-2020, 08:39 AM   #5
kenparker0703
That little "triangle shaped guide" is nothing but a line up guide in the hub. I use a pres that makess 28 to 30 tons. All that pressure has to be on the stud - not he drum. Takes a special "jig" to get everything square and level or you WILL crack drum or hub Recommend yo take the drum/hub to someone that has right equipment and has done it.
kenparker0703 is offline   Reply With Quote
Old 12-09-2020, 06:16 PM   #6
jack wingard
Snyder sells the swedging tool.I had them do mine since I was installing all new drums.
jack wingard is online now   Reply With Quote
Old 12-17-2020, 09:27 PM   #7
Mike Barrett
Do you have the contact info for Snyder or anyone who sells the swedging tool
Old 12-17-2020, 09:34 PM   #8
Doug Linden
Doug Linden's Avatar
My local auto machine shop has the tools in house to that work, maybe you could check around your area to find a shop that can do this job for you.
Doug Linden is offline   Reply With Quote
Old 12-17-2020, 10:20 PM   #9
redmodelt
redmodelt's Avatar
Before you even start to mount the drums to the hubs, make sure the flange is straight, many are not. We bolt everything together using large washers to bridge the hub and drum with studs installed. Just like changing a tire, do one then one across from it etc.
Old 12-18-2020, 04:16 AM   #10
jack wingard
www.snydersantiqueauto.com
Old 12-22-2020, 08:51 AM   #11
Mike Barrett
Thanks, have ordered a stud installation tool, Problem with living in Canada, $7.95 for tool -$20.00 shipping.
Tool arrived today, wow they're fast.
