Old 02-10-2011, 06:29 PM   #1
Gerard
Gerard's Avatar
Default Guide coat color ??
As I have just finished after numerous hours of sanding and lightly applying some bondo at some places and some places and followed by 3 layers of sandable primers on my 4 door.
I continue with PPG concept ( maroon / Black ) awful expensive paint by the way.
What do guy's advise for a colour to guide coat ??? and how thick should I spray this . Just a mist ?? Or just cover with a light coat to practically cover the grey primer ? ( black primer or dye for was not available here )
Thanks,
Gerard
Gerard is offline   Reply With Quote
Old 02-10-2011, 07:03 PM   #2
Ed Northrop
Ed Northrop's Avatar
Default Re: Guide coat color ??
I use black when I use gray primer and just mist on a light coat so when I block sand low spots show. I start with 180 grit and work down then spray on more primer.
Ed Northrop is offline   Reply With Quote
Old 02-10-2011, 07:39 PM   #3
fordcragar
fordcragar's Avatar
I always used a red oxide primer, for a guide coat, over gray primer. Just mist in on. Some guys use paint, I always found that it clogged the sandpaper more than primer.
fordcragar is offline   Reply With Quote
Old 02-10-2011, 08:05 PM   #4
Craig Lewis
Craig Lewis's Avatar
Gerard I would get an aerosol can of black lacquer & dust on a very thin transparent coat.
Canadian tire has it in the hardware dept., by Rustoleum corp, called "Specialty Lacquer" in a green can, bar code#20066 16901.
**Don't buy anything that says enamel.
Enamel dries slower, plugs the paper and in the event that some enamel stays on the car (in a crack or crevice) it could possibly wrinkle or lift under the new paint.
Be sure to sand the primer as thin as possible at your edges...like door edges and especially the hood hinge area to avoid easy chipping.
Someone (Marco?) wrote an article about filing (not filling) the hood hinge joints to eliminate all primer where it pivots.
Less is more.
Craig Lewis is offline   Reply With Quote
Old 02-10-2011, 10:57 PM   #5
Gerard
Gerard's Avatar
Thank you all for the advice guy's, will follow up on that. I was a bit concerned that the ordinary rattle can paint would cause he final coat to chip ( final coat is Concept acrylic Urethane )
Old 02-10-2011, 11:15 PM   #6
pooch
pooch's Avatar
You may be thinking a guide coat is a full coat.
It is not, just a mist of black rattle can will do.It sands off instantly and only stays in low spots, which obv needs more work before topcoating.
pooch is offline   Reply With Quote
Old 02-11-2011, 12:30 AM   #7
Craig Lewis
Pooch is right.
When ALL the guidecoat is sanded off, the panel is flat...theoretically.
How fine are you sanding? and are you using an epoxy seal coat just before the colour?
Also Gerard... is Concept paint or the reducer available in your area? I understand it's done with in Canada and many of the states.
Old 02-11-2011, 03:52 AM   #8
Gerard
Gerard's Avatar
Hi Graig , yes you are right in Canada the epoxy paint's are not available over the counter anymore. But as you may know Creston is direct at the border with US and there is a supplier in Sandpoint who ships the stuff direct to a shipping address I have in Porthill.I sanded the car first with 180 grid did some bondo here and there ( I used less 1/2 quart for the whole car ) then 1 coat epoxy primer I then continued with omni mp 802 , 3 coats with light sanding in between. Tomorrow I give the bird a guide coat and start block sanding again. Hell of a job by the way.
Old 02-11-2011, 04:31 AM   #9
Mike V. Florida
Mike V. Florida's Avatar
Take a look here;
DRY COAT
Old 02-11-2011, 11:37 PM   #10
CWPASADENA
CWPASADENA's Avatar
I use Krylon Red Oxide Primer or it may be called Krylon Brown Sandable Primer. Dries quick and well not clog the paper. Just mist it on. You do not have to have full coverage, just a mist. It will really jump out to you where the low spots are when you start to sand.
Chris
CWPASADENA is offline   Reply With Quote
Old 02-12-2011, 08:07 AM   #11
allen
allen's Avatar
Send a message via ICQ to allen
Mike has it right, use 3m dry coat, no waiting, no clogging, no breathing in fumes, and will enough to do about 4 cars good luck
allen is offline   Reply With Quote
Old 02-12-2011, 08:25 AM   #12
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
That is what we use. I was hesitant to say anything about it for fear that someone would complain about something else to buy.
I will say that I am not in favor of applying any type of 1K type product (spray primer in a can) under a 2K primer simply for fear of contamination and adhesion issues surfacing later. I realize there are many things done (like using lacquer thinner mixed with urethane paint) that people here feel is OK, but it just isn't for me. With Paint & Materials costs around $1,000.00, skimping on $35 can of guidecoat to save $20 is foolish.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 02-12-2011, 04:53 PM   #13
Aerocraft
Aerocraft's Avatar
I'll add my vote for 3M's Dry Guide coat. It is black, cheap, and when used over PPG's K-36 is the cat's meow! Gar Williams
Aerocraft is offline   Reply With Quote
Old 02-13-2011, 01:48 PM   #14
cars56
Hope you are using a supplied air respirator for your project
Just read the warning labels on those cans
cars56 is offline   Reply With Quote
Old 02-19-2011, 09:27 PM   #15
Gerard
Gerard's Avatar
Thanks for the reply I have bought the 3M dry coat , but......... here in canada they charged me 110 CAD minus 30 % jobber discount and on the end it still was around 78,-- #%&^%&^%&^%
Old 12-24-2016, 04:48 AM   #16
RUNNERBUN
RUNNERBUN's Avatar
Post 16 is reported
Adjust your points with gentle blows of a 2 pound hammer
RUNNERBUN is offline   Reply With Quote
