Old 03-30-2020, 11:12 AM   #61
V8COOPMAN
V8COOPMAN's Avatar
Default Re: This AWFUL Bug...Explained!
To mike in tucson ...Even more valuable info describing an entirely different aspect of this malady. Info that again, is absolutely pertinent to all, yet never shared by any of the MSM. Thank you, Mike! Dick D
Click Links Below __
T5 W/TORQUE TUBE
Old 03-30-2020, 12:39 PM   #62
mike in tucson
Virus vs. Germs require completely different approaches to control them.... I just read an article regarding the spread of the corona virus.... there is an "average" transmission where a single case infects 2.5 new cases. The flu (or instance) has a transmission of about 1.3. Measles is really contagious.... one case transmits to 15 others.
mike in tucson is offline   Reply With Quote
Old 03-31-2020, 03:31 AM   #63
Tinker
Tinker's Avatar
https://www.youtube.com/watch?v=BtN-goy9VOY
Old 04-01-2020, 07:00 PM   #64
A bones
A bones's Avatar
Default Re: "How Covid 19 Kills"
"How Covid 19 Kills" subtitle "I'm A Surgeon---We Can't Save You"
My wife found this on you tube.
Take the time to GET SMART!!
I Love Fordbarn Always. Sorry Tubman, Ol Ron and others.
I know we all just want to drive, work on, read about, and look at, Heroic old Fords.
Stay Protected, Stay With Us.
Take The Time To Check Out This youtube. "How Covid 19 Kills"
Thanks Mike
Originally Posted by mike in tucson View Post
Johns Hopkins University Sent this excellent summary:
* The virus is not a living organism, but a protein molecule (DNA) covered by a protective layer of lipid (fat), which, when absorbed by the cells of the ocular, nasal or buccal mucosa, changes their genetic code. (mutation) and convert them into aggressor and multiplier cells.
* Since the virus is not a living organism but a protein molecule, it is not killed, but decays on its own. The disintegration time depends on the temperature, humidity and type of material where it lies.
* The virus is very fragile; the only thing that protects it is a thin outer layer of fat. That is why any soap or detergent is the best remedy, because the foam CUTS the FAT (that is why you have to rub so much: for 20 seconds or more, to make a lot of foam). By dissolving the fat layer, the protein molecule disperses and breaks down on its own.
*HEAT melts fat; this is why it is so good to use water above 25 degrees Celsius (77 degrees F) for washing hands, clothes and everything. In addition, hot water makes more foam and that makes it even more useful.
* Alcohol or any mixture with alcohol over 65% DISSOLVES ANY FAT, especially the external lipid layer of the virus.
* Any mix with 1 part bleach and 5 parts water directly dissolves the protein, breaks it down from the inside.
* Oxygenated water helps long after soap, alcohol and chlorine, because peroxide dissolves the virus protein, but you have to use it pure and it hurts your skin.
* NO BACTERICIDE SERVES. The virus is not a living organism like bacteria; they cannot kill what is not alive with anthobiotics, but quickly disintegrate its structure with everything said.
* NEVER shake used or unused clothing, sheets or cloth. While it is glued to a porous surface, it is very inert and disintegrates only between 3 hours (fabric and porous), 4 hours (copper, because it is naturally antiseptic; and wood, because it removes all the moisture and does not let it peel off and disintegrates).
24 hours (cardboard), 42 hours (metal) and 72 hours (plastic).
But if you shake it or use a feather duster, the virus molecules float in the air for up to 3 hours, and can lodge in your nose.
* The virus molecules remain very stable in external cold, or artificial as air conditioners in houses and cars. They also need moisture to stay stable, and especially darkness. Therefore, dehumidified, dry, warm and bright environments will degrade it faster.
* UV LIGHT on any object that may contain it breaks down the virus protein. For example, to disinfect and reuse a mask is perfect. Be careful, it also breaks down collagen (which is protein) in the skin, eventually causing wrinkles and skin cancer.
* The virus CANNOT go through healthy skin.
* Vinegar is NOT useful because it does not break down the protective layer of fat.
* NO SPIRITS, NOR VODKA, serve. The strongest vodka is 40% alcohol, and you need 65%.
* LISTERINE IF IT SERVES! It is 65% alcohol.
* The more confined the space, the more concentration of the virus there can be. The more open or naturally ventilated, the less.
* This is super said, but you have to wash your hands before and after touching mucosa, food, locks, knobs, switches, remote control, cell phone, watches, computers, desks, TV, etc. And when using the bathroom.
* You have to HUMIDIFY HANDS DRY from so much washing them, because the molecules can hide in the micro cracks. The thicker the moisturizer, the better. * Also keep your NAILS SHORT so that the virus does not hide there.
Thank you Mike.
Enjoy yer day. Tom
Hate can't fix what it started.
A bones is offline   Reply With Quote
Old 04-02-2020, 09:28 AM   #65
Tim Ayers
I just found out my good friend pass away this morning. Went in last week. Started on oxygen and then they put him in a medical induced coma and ventilator. This week, the virus started to attack his organs. Passed away this morning. Three kids (youngest is 9 yo) and a beautiful wife. None of them were able to be with him nor was he able to say good bye.
Only reason I'm telling you is please be careful and heed all warnings and recommendations.
My friend was a picture of health and strong as an ox. When I spoke to him last, he said this was the hardest thing he's ever gone through.
In the end, he couldn't fight any longer.
RIP, Jimmy. You will be missed.
Old 04-02-2020, 12:04 PM   #66
V8COOPMAN
V8COOPMAN's Avatar
Serious stuff beyond comprehension here folks, the likes of which we have NEVER seen before! I'm so sorry to hear about your friend, Tim! DD
T5 W/TORQUE TUBE
