Old 12-08-2018, 03:26 PM   #1
burner31
burner31's Avatar
Default Winter car work 2018
When the snow starts falling and and my driving is done for the year, here's what's on the menu for the Winter...so far.
What's on your list?
Engine
• Change head gasket
• New water temp gauge
• Change oil
• Clean water jacket
• Clean engine
• Tranny dip stick
• Check tranny fluid
• Install engine pans
• Remove/Flush radiator
• Install radiator sock
• Rebuild distributor (modern)
Misc:
• Brake anti rattle RF. LF, RR, LR, Ebrake
• Adjust brakes
• Lube joints
• Check rear end
• Lube leaf springs
• Oil door hinges RF. LF, RR, LR
• Remove weld on rear door hinge
• Run magnet on fly wheel
• Seal roof leaks-DONE
• Adjust windshield
• Tires - tubes, liners, mount, install beads - DONE
• Install front plate
Steering
• Tighten steering wheel
Electrical
• Modern points
• Clean/adjust light switch
• Check/repair electrical connections
• Starter brush set
• Generator Brush Set
Horn
• clean/lube horn
Interior
• window crank repair - Mac's
• Fix dash light
Keith
Shawnee OK
'31 SW 160-B
burner31 is offline   Reply With Quote
Old 12-08-2018, 04:27 PM   #2
30 Closed Cab PU
Default Re: Winter car work 2018
That is quite a list. Lots more than I do.
Suggestions.
Check differential fluid.
Repack wheel bearings/seal replacement if needed.
Service Fuel System
Check for Gas Shutoff Valve leakage. Flush and completely Drain Gas Tank. Clean - Pencil filter, Gas bowl and screen, Carb Filter. Drain Carb Bowl. Fill Tank with non gasohol Gas mixed with Marine Stabil. Check Float level.
I assume your steering wheel mounts to the Dash on your 31, if not update it.
Check/Clean/Gap Spark Plugs. Check Rotor Gaps.
As long as you have got the radiator off and are changing the head gasket backflush the Block/head, visually check for rust/scale.
Change over to Antifreeze for storage if you are running water in the summer.
30 Closed Cab PU is offline   Reply With Quote
Old 12-08-2018, 04:45 PM   #3
Step-down
Step-down's Avatar
Adjust valve lash on my AV8
"I can't cry as long as I know the Lord has risen "
Step-down is offline   Reply With Quote
Thread Tools
Display Modes
