Old 03-30-2018, 09:53 AM   #1
Al 29Tudor
Al 29Tudor's Avatar
Default Removing Transmission
Good morning,
After removing the differential and universal will I have to remove the brake cross shaft to remove the transmission from the car? Engine is staying in place.
Thanks for your help.
Al
Al 29Tudor is offline   Reply With Quote
Old 03-30-2018, 10:24 AM   #2
Jacksonlll
Jacksonlll's Avatar
Default Re: Removing Transmission
You don't have to remove the cross shaft.
Old 03-30-2018, 11:27 AM   #3
figment
Removing the brake cross shaft does help some when re-installing the ujoint and rear end . It lets you line up the splines . It can be done with the cross shaft in place but for me it seemed easier with it removed . Norm
figment is offline   Reply With Quote
Old 03-30-2018, 02:27 PM   #4
Al 29Tudor
Al 29Tudor's Avatar
OK thank you Gents.
I appreciate your input.
Al
Old 03-30-2018, 03:16 PM   #5
larrys40
Al,
I would NOT remove the cross shaft. If you take off the U-joint by using a 9/16 on an extension you can remove the U-joint and as jackson said have ample clearance.
I like using some alignment pilots ( bell housing bolt size with heads cut off and tapered) to help in aligning it back so you don't torque the clutch disc and it's overall easier. I think about 2 1/2 to 3 inches I believe is good on the alignment bolts. Screw one in on each side.
All the best!
Larry Shepard
larrys40 is offline   Reply With Quote
Old 03-30-2018, 04:13 PM   #6
jm29henry
jm29henry's Avatar
Jackson & Larrys40 are right
jm29henry is offline   Reply With Quote
Old 03-31-2018, 06:18 AM   #7
Al 29Tudor
Al 29Tudor's Avatar
Larrys40,
I like the idea of using alignment pins in the flywheel housing to align the bell housing.
Good one! Thanks
