Old 09-23-2020, 06:28 PM   #1
Cape Codder
Cape Codder's Avatar
Default Front Spindle Measurements
Can someone give me the diameter of the front spindles at the rear wheel bearing as well as at the outer wheel bearing?
Cape Codder is offline   Reply With Quote
Old 09-23-2020, 09:19 PM   #2
1930-Pickup
Default Re: Front Spindle Measurements
Do you mean 'inner'?
Are you looking for the Ford spec, or what people have measured?
It helps to know what you're working on.
Are you troubleshooting the fit of bearings to spindles?
If so, to find the problem, you would need the Ford specs, which I don't have.
"That's my wild unsubstantiated guess, and I'm sticking to it regardless of the facts!"
1930-Pickup is offline   Reply With Quote
Old 09-24-2020, 10:52 AM   #3
katy
katy's Avatar
Here's some part numbers, you can probably pull up the dimensions using these numbers:
Front wheels
A–1201 Front wheel inner race 15250 Timken
A–1202 Front wheel inner bearing 15118 Timken
A–1216 Front wheel outer race 09196 Timken
A–1216 Front wheel outer race 09194 BCA Federal Mogul
A–1217 Front wheel outer bearing 09074 Timken
A–1217 Front wheel outer bearing 67048 LM
Old 09-25-2020, 04:24 PM   #4
Doug Linden
Doug Linden's Avatar
Joe, just measured a spare I had.
inner = 1.189"
outer = .750"
Hope this helps.
Doug Linden is offline   Reply With Quote
Old 09-26-2020, 09:39 AM   #5
Cape Codder
katy - Thanks for the P/N information!
Doug Linden -Thanks Doug for the measurements!
