Old 02-21-2015, 05:42 PM   #1
Cracker39
Cracker39's Avatar
Default Engine Splash Pans
Is there a difference between the engine splash pans for 28, 29, 30 and 31 cars? i.e. - hole spacing, shape, etc.? Bratton seems to sell "one size fits all."
Cracker39 is offline   Reply With Quote
Old 02-21-2015, 05:43 PM   #2
Fred
Default Re: Engine Splash Pans
Yes, Many ..
Fred is offline   Reply With Quote
Old 02-21-2015, 11:18 PM   #3
DougVieyra
DougVieyra's Avatar
For starting your 'Ball Park' investigation into engine splash pans, recognize that there are two basic types: those made for the 1928-'29 fender style, and yet another design for the later 1930-'31 fender styles. Each of the types may have minor variations as to hole fitting, but they are pretty much the same for each of the two different body/fender styles - the '28-'29 style, and the slightly different '30-'31 style.
DougVieyra is offline   Reply With Quote
Old 02-21-2015, 11:50 PM   #4
daveymc29
daveymc29's Avatar
I have been told most of the vendors list only one size to fit all. They are a better fit for the 30/31 than the 28/29, though the will work, but not for judging. With a little hammer work they will be a better fit on the 28/29 that straight off the shelf. They are a tad far away at the front cross member. compared to the originals.
daveymc29 is offline   Reply With Quote
Old 02-22-2015, 09:22 AM   #5
Fred
FYI, For the 1928 cars/trucks they are not even close !!..
Old 02-22-2015, 09:52 AM   #6
kenparker
kenparker's Avatar
While working on a customers/friends Model A I discovered and ingenious, as I ahve never seen this before, way to install the Engine Pans. And, yes, engine Pans are a pain in the horse to install when one is by themself. The 1/4" holes in the frame for the 1/4" bolts have been drilled out and tapped for 5/16" bolts. Now all I have to do is lay on my back on the cold concrete and screw the 5/16" bolt upwards into the frame tapped hole. Almost easy.
Is it the way Henry did it? No. Does it work? Yes. ken
kenparker is offline   Reply With Quote
Old 02-22-2015, 11:39 AM   #7
Maclab58
Maclab58's Avatar
Great idea.
Maclab58 is offline   Reply With Quote
Old 02-22-2015, 03:03 PM   #8
pgerhardt
pgerhardt's Avatar
Here is another thought. Rather than up sizing to 5/16" and tapping, how about a touch of JB weld on the 1/4" nut to attach it to the frame? Just a thought?
pgerhardt is offline   Reply With Quote
Old 02-22-2015, 03:04 PM   #9
Mitch//pa
i dont have any trouble installing them the proper way
Old 02-22-2015, 03:47 PM   #10
Charles Reese
Charles Reese's Avatar
It is my understanding ...
* Until Oct ’28, each pan included flattened tab at its front end. Each pan bolted to the frame at 6 points (3 to frame, 2 to oil pan bolts, 1 to front cross member). After that, possibly due to their rigidity (cracking) and change in the engine mount, the front tabs were folded up and the bolt hole eliminated..
* Initially, unique-head bolts were drilled for cotter pin (no lock washer). After mid ’29, the bolts were not drilled and used lock washers. Bolts were inserted from the top side of frame.
*A20553 Engine pan to frame bolt (cross drilled for cotter): 1/4”-28 x 9/16” (fillister head screw) …{plain}
*A21666 Engine pan to frame bolt (thick head, square) … slight chamfer on top face of nut: 1/4”-20 (3/16”t x 1/2”) …{plain}
*A23515 Engine pan to frame bolt cotter: 1/16” x 1/2” …{plain}
Charles Reese is offline   Reply With Quote
Old 02-22-2015, 04:10 PM   #11
Synchro909
Synchro909's Avatar
Are the pans the same for RHD and LHD? Does the steering box/pitman arm foul them if I try putting the repro ones now available on a RHD car.
Old 02-22-2015, 05:15 PM   #12
Tom Wesenberg
Tom Wesenberg's Avatar
Charles, did you mean to say "hex head" rather than "fillister head"?
I don't recall ever seeing fillister head on engine side pans.
Old 02-22-2015, 10:13 PM   #13
glenn in camino
glenn in camino's Avatar
I did that on my modified car, I know it's not correct, but it's much easier.
Old 02-22-2015, 11:55 PM   #14
Mike V. Florida
Mike V. Florida's Avatar
Another case of the restoration guidelines coming in handy.
Old 02-23-2015, 10:45 AM   #15
Cracker39
Cracker39's Avatar
I've been waiting for someone to say just what the "variations" are in the vendor supplied pans with respect to a '31. Do the mounting holes in the pans need to be elongated or re-drilled - or does the pan need to be trimmed or re-bent?
Old 02-23-2015, 01:06 PM   #16
briphaeton
I picked these up many years ago and was told they also used spring as shown in photo.
Explains the reason that both nut and bolts were drilled.
Brian
briphaeton is offline   Reply With Quote
Old 02-24-2015, 10:50 PM   #17
Charles Reese
Originally Posted by Tom Wesenberg View Post
Charles, did you mean to say "hex head" rather than "fillister head"? I don't recall ever seeing fillister head on engine side pans.
Hmmmm …. On boy! Me thinks I’ve open a can of worms (bolts/nuts)!!!
As an aside, I found a typo in my original entry: A21666 Engine pan to frame bolt (should read NUT) (thick head, square) … slight chamfer on top face of nut: 1/4”-20 (3/16”t x 1/2”) …{plain}.
My original engine pans (Jan 28 vehicle) were secured with the hex head bolts (w/ chamfered edges and cotter hole) I showed earlier in this thread … that doesn’t make it right, just what I found.
The info I posted is from Mick Isbell’s Hardware Manuel:
* A-20553 1/4-28 x 9/16 fillister head screw (8 needed)
-- notation “deleted Dec 1929”
-- in retrospect, it makes no sense that this would be a ‘fillister head’ … this may be an example of the transposition of data in the Manual that has been discussed on FB previously. My apologies for leading us astray!!
* A-20534 1/4-28 x 1/2 bolt
-- no mention of cotter hole
-- presumably, this was after Dec ’29 and may have coincided with the change in the mounting of the pan at the front cross member
* A-21666 1/4-20 (3/16 x 1/2) square nut
?? notice that the bolt is 28 thread; the nut 20 thread {typo?}
The 1-1-28 PPL & 10-1-28 PPL shows:
*A-20553 1/4-28 SAE x 9/16 square head bolt with cotter hole (8 needed)
-- this conflicts with the unique hex-head bolts which I believe were original to my vehicle
* A-21666 1/4-20 SAE (3/16 x 1/2) square nut (6 needed)
I dont have the various PPLs between these dates ...
The 7-1-31 PPL shows:
* A-20553 & cotter apparently obsoleted by now
* A-20534 1/4-28 x 1/2 hex head bolt (no mention of cotter hole)
* A-22150 lock washer
Old 02-25-2015, 12:02 AM   #18
Tom Wesenberg
Thanks Charles,
I do recall the nut thread count being a mistake in the original PPL, and it should be 28 TPI.
Old 02-25-2015, 12:40 PM   #19
Charles Reese
Thanks Charles, I do recall the nut thread count being a mistake in the original PPL, and it should be 28 TPI.
what's your thoughts re: the discrepancy between the PPL saying 'square head' and my 'hex head' bolts? other 'early' guys have assured me that the hex style i have is correct.
Old 02-25-2015, 01:28 PM   #20
Tom Wesenberg
Hex is all I've seen, so I'd believe the "SQUARE" is another mistake.
