Old 02-24-2018, 07:40 PM   #1
Ian in Mississauga
Default Model B condenser
I have a model B distributor that I want to try. I already have a B timing gear cover and an ignition cable that will work. I had planned to use a model A condenser from A&L. Here's the problem: I see from Vince Falter's site that the 2 condensers have different capacitances.(.20-.25 microfarads for the A and .45-.63 for the B). Is the A&L condenser still a good choice?
Ian in Mississauga is offline   Reply With Quote
Old 02-24-2018, 07:44 PM   #2
J Franklin
J Franklin's Avatar
Default Re: Model B condenser
I would use a condenser with the correct compactly.
Old 02-24-2018, 08:06 PM   #3
Bob C
Totally different condenser, Berts has new USA B condensers.
https://parts.modelastore.com/show_Product.asp?ID=4240
Bob
Old 02-24-2018, 09:31 PM   #4
Charlie Stephens
Does anyone know why there would be two different capacities?
Charlie Stephens
Old 02-24-2018, 10:26 PM   #5
CWPASADENA
CWPASADENA's Avatar
Charlie Stephens
It may be because of the longer dwell time with the B distributor?
I have been told the grind on the B Distributor Cam is different than the A because they were trying to get more dwell time for better coil saturation and a hotter spark.
Chris W.
CWPASADENA is offline   Reply With Quote
Old 02-24-2018, 10:34 PM   #6
Synchro909
Synchro909's Avatar
Just guessing here but I do know that the coil and condenser have to be matched or the points will burn out. Maybe Ford used a different coil with the B engine.
I'm part of the only ever generation with an analogue childhood and a digital adulthood.
Old 02-24-2018, 11:56 PM   #7
ursus
Chris W.
If that is the case, then we better warn all the guys running B distributor cams in their Model A distributors. I find the claim of such a great difference in capacitance hard to believe as I have used both A and B condensers in my Model B distributors, with no noticeable difference. I've even used the early V-8 condensers, again with no noticeable difference.
ursus is online now   Reply With Quote
Old 02-25-2018, 02:07 AM   #8
Tom Wesenberg
Tom Wesenberg's Avatar
I wonder if the B reading is a misprint somewhere along the line?
All the ignition capacitors I know of are between .20 and .30 microfarads.
Old 02-25-2018, 10:00 AM   #9
Bob Bidonde
Bob Bidonde's Avatar
The condenser absorbs the current spike that occurs in the primary coil winding when the points open and the field collapses. So the condenser is a match to the coil, not the points.
Typically, distributor coils use a 600V, 0.25-0.29 microfarad condenser.
Bob Bidonde
Old 02-25-2018, 10:34 AM   #10
CT Jack
CT Jack's Avatar
They will both work. The B condenser will store 2 times more energy (more electrons) which might provide a slightly hotter spark. I am just guessing this because I have never seen any testing results to prove that the B distributor with a 0.5 microfarad condenser works better than a 0.25 condenser. BTW 1 microfarad = 1 X 10 to the minus 6th farands.
CT Jack is offline   Reply With Quote
Old 02-25-2018, 05:57 PM   #11
Synchro909
Synchro909's Avatar
Exactly right. That's why I guessed that because they used a different condenser, Ford might have used a different coil on the B engines.
FWIW,
A few years ago, I was building a replica 1920's Grand Prix car and I had bought a Bosch coil for it. I rang their technical department to find out what condenser should go with it. The young guy at the other end didn't have a clue what I was talking about but said that the "old guy" in the office might know. He'd ask and get back. To my surprise, he did ring back and was clearly amazed that the "old guy" knew without using a computer.
Old 02-25-2018, 06:13 PM   #12
ursus
My understanding is that, at some point, Ford no longer supplied the Model A-xxxx numbered coil as a replacement and directed the dealers to supply the Model B-xxxx coil for replacement in the Model-A. This would imply there wasn't much if any difference.
Old 02-26-2018, 10:31 AM   #13
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
If the burned SPIKE is on 1 point, the capacity is TOO GREAT. If it's on the opposite one, it's TOO LITTLE. If NO SPIKE, IT'S JUST RIGHT!
Bill Scientific
"THE ASSISTANT GURU OF STUFF"
