Old 11-06-2012, 02:45 PM   #1
ceejay
Default Cowl Lights on 33 vs 34
HI All,
Were Cowl lights fitted to 33 cars ? if so, what is the difference between 33 and 34 Cowl lights ?
ceejay is offline   Reply With Quote
Old 11-06-2012, 02:55 PM   #2
deuce lover
deuce lover's Avatar
Default Re: Cowl Lights on 33 vs 34
Yes 33 deluxe cars had them.As far as I know the are the same for both years.There were holes just above the reveal in front of the windshield post.Look underneath and you should see indications.If your car is a standard I personally would leave it that way.Standard phaetons have low production numbers.
deuce lover is offline   Reply With Quote
Old 11-06-2012, 03:00 PM   #3
David J
David J's Avatar
Standard item on deluxe cars . Extra cost on std cars . There are slight differences in body depth on 33-34 cowllights but this seems to be inconsistent so it may well be just different suppliers . Headlights are a different story with 33 NOTICEABLY deeper than 34 . As your car has holes for them I'd use-em . Besides they aren't expensive or hard to find . What's on your car is not the proper ones .
Originally Posted by ceejay View Post
HI All,
David J is offline   Reply With Quote
Old 11-06-2012, 03:07 PM   #4
bill3337
bill3337's Avatar
I have original '33 cowl lights on my '33 and they are more bullet shaped than the '34's to mimmick the shape of the '33 headlights. It's a minor enough difference that you have to be aware of it to notice it. Bill
bill3337 is offline   Reply With Quote
Old 11-06-2012, 03:30 PM   #5
DavidG
DavidG's Avatar
I second DavidJ's comment. Of the six each '33 and '34s that I've owned with cowl lamps, there was no consistent difference of the depth of the cowl lamps, even though I attempted to find one. Further, Ford's engineering release documents make no mention of a dimensional change in the cowl lamp housings, unlike the notable change in the depth of the headlamp housings.
P.S.
ceejay,
Please promise not to replace those Marchal Optique head lamps with typical '33-'34 headlamps; they are the vastly superior in appearance (and were used by Ford in some European jurisidictions).
David
Old 11-06-2012, 05:08 PM   #6
millersgarage
millersgarage's Avatar
now I am curious about the headlamps. I didn't know there was a difference in 33 to 34??
millersgarage is offline   Reply With Quote
Old 11-06-2012, 05:24 PM   #7
ken ct
Oh yea. ken ct.
ken ct is offline   Reply With Quote
Old 11-06-2012, 08:34 PM   #8
David J
David J's Avatar
33 on the left & 34 on the right .
Old 11-06-2012, 11:57 PM   #9
ceejay
DavidG, wow, There I was thinking someone had fitted some cheap crappy lamps into the original 33 housings.... the chrome housings have the word ford (and something else) stamped on them and they are very deep... I will take photo and post.
So those Marchal lamps are probably original to the car ??
The glass on those bulge out a LOT compared to the relatively flat glass of the typical 33/34 units.
David, I am waiting for your e-mail when ever you can find the time
Old 11-07-2012, 10:05 AM   #10
millersgarage
Thank you David J
Old 11-07-2012, 11:40 AM   #11
fordcpe
fordcpe's Avatar
My 34 coupe has 33 lights because I like them bigger.I have looked for 33 cowl lights and found none longer slightly different shape maybe but hard to tell.I have a card board template and tried on lots of lights.Darrell
fordcpe is offline   Reply With Quote
Old 11-07-2012, 09:03 PM   #12
Ziffer
I've got both the deep and shallow cowl light. I've collected many 33-34 lights through the years and the deeper ones are definitely very hard to find.
Ziffer is offline   Reply With Quote
Old 11-07-2012, 09:40 PM   #13
ceejay
Ziffer if you would sell 2 deep cowl lights please let me know
Old 11-08-2012, 03:03 AM   #14
David J
David J's Avatar
If this is the gauge of knowledge on 33-34 cowl lights this is one drawer of these . I have more . No I don't want to part with any and I am always looking for more with PRODUCTION LENSES . THATS the difficult part with these little fellas . The two on the left in the rear row show the longest and the shortest BUT there are FOUR different depths in the back row alone . As I stated above there isn't really any consistencey to this . A question for the cowl light guru's here . Do any of you know the 4 digit number that is on PRODUCTION lenses ?
Old 11-08-2012, 04:18 PM   #15
FL&WVMIKE
FL&WVMIKE's Avatar
DAVID J. .....................
I'm learning something here. I had always ASSUMED that the 1933s were longer than the 1934s. I had no idea that there were several different lengths !
MIKE
FL&WVMIKE is offline   Reply With Quote
Old 11-08-2012, 06:59 PM   #16
DavidG
DavidG's Avatar
David,
That's consistent with my experience. Finding two exactly the same depth is something of a challenge.
David
