Old 01-10-2021, 08:47 PM   #1
fiddy6
Default Ford 56 Starter
Hi Guys,
My starter drive has broken (see attached image).
is this a suitable replacement?
https://www.dennis-carpenter.com/car...do-not-twist-d
It doesn't quite look the same but appears to be correct.
I have a ecz-c 312 y block from a tbird in a 1956 ford victoria.
Cheers
Geoff
fiddy6 is offline   Reply With Quote
Old 01-10-2021, 09:35 PM   #2
Dobie Gillis
Dobie Gillis's Avatar
Default Re: Ford 56 Starter
It's correct if you have have a Fordomatic transmission. Manual cars use a different drive, identifiable by 2 bolts that hold it together.
Often wrong but never in doubt.
Dobie Gillis is offline   Reply With Quote
Old 01-10-2021, 10:58 PM   #3
fiddy6
Yes fordomatic
Old 01-11-2021, 03:30 PM   #4
hotrodart
hotrodart's Avatar
Interesting post......I changed my '56 Victoria 312 engine from FORDOMATIC to stick shift using a "parts car" as a donor. I guess I was too dumb then (back in '64) to know about the starter differences. I just used to original starter and it worked fine for 10 years and more than 100K miles. Who knew?......
hotrodart is offline   Reply With Quote
Old 01-11-2021, 05:10 PM   #5
darrell
there were different drives but but i never heard that before.im sure ive mixed them.
darrell is offline   Reply With Quote
Old 01-11-2021, 05:56 PM   #6
scicala
scicala's Avatar
On my '55 Mercury, I converted it from a Mercomatic to a Borg Warner T10 4 speed from a '63 390. I used a factory '55 stick shift bellhousing, and never had any issues with the starter. I think maybe if you swap from a stick shift to an automatic, that may present the problem, with the end of the starter drive hitting on the torque converter ? Just a guess. I know when I bought a rebuilt starter from an auto parts store, they never asked me if I had a manual or automatic.
Sal
Old 01-11-2021, 06:17 PM   #7
fiddy6
I think I'll gamble and just get that one. I'll update here as I go.
Cheers
