Old 01-09-2021, 01:01 PM   #1
STAN WHITE
Default 34 ford fender welting
Would like info on installing fender welting on the front fenders of a 34. Any secrets on the procedure? Thanks Stan
STAN WHITE is offline   Reply With Quote
Old 01-09-2021, 01:11 PM   #2
DavidG
DavidG's Avatar
Default Re: 34 ford fender welting
it runs from side to side in one piecee and is attached to the transition piece between the fenders directly below the peak of the bottom of the grille with a binding head screw.
Old 01-09-2021, 01:20 PM   #3
Ken Arms
Ken Arms's Avatar
Take your time and mark every hole, use a punch for the bolts to go through. Check with third gen, he may have the good welting like original. Ken
Ken Arms is offline   Reply With Quote
Old 01-09-2021, 02:48 PM   #4
STAN WHITE
Thanks Ken I got it from Third Gen. I wanted the old style stuff with SOLID CORE iT ALLOWS YOU TO MAKE A BEND AND WONT FLATTEN OUT.The other style with plastic tubing for the core flattens out when bending for the end of a run. Stan
Old 01-09-2021, 09:20 PM   #5
Bluedot
Besides making the bolt holes, you may need to make some V cuts on the flat portion when having to do a curve.
Bluedot is offline   Reply With Quote
Old 01-10-2021, 04:12 AM   #6
Graham Freeman
If you use the plastic tubing style you can insert, aluminium, brass or similar tubing inside and shape the ends of the welting to suit.
Graham Freeman is offline   Reply With Quote
