11-18-2010, 08:13 AM | #1 |
1953 Ford with 8v battery.
Purchased a 53 Ford Victoria with an 8v battery. Don't know if any adjustments have been made to the electrical system but my turn
signal and break light bulbs keep blowing after minimual use. Any suggestions? |
11-18-2010, 08:47 AM | #2 |
Re: 1953 Ford with 8v battery.
Buy a 6 volt battery....
11-18-2010, 08:54 AM | #3 |
Thanks EdB. Just trying to avoid the cost!
11-18-2010, 08:58 AM | #4 |
Buy a 6 volt battery and clean all electrical connections. The starter may need to be clean up inside also. Back in the old days a 8 volt battery was the easy way for a fix because most did not have a garage or a decent place to work on there cars like us today.When I got my 50 it started slow like a weak battery so I clean the battery post and the grounds straps and bolts now starts strong.Just a bit of tender care will do the job.
11-18-2010, 09:02 AM | #5 |
Know adjustments where made thats why those blubs are blowing voltage regular needs to be adjusted to the battery or change back to asix volt battery the better Idea goodluk.
04-29-2013, 12:38 AM | #6 |
04-29-2013, 09:34 AM | #7 |
An 8 volt battery may be better with the summer months coming, save your self a few bucks and adjust regulator,,,gump
"I believe God is managing affairs and that He doesn't need any advice from me. With God in Charge, I believe everything will work out for the best in the end. So what is there to worry about". Quote by Henry Ford |
Thread Tools | |
Display Modes | |
