Old 08-31-2013, 09:52 PM   #1
Hayshaker
Default New engine
Hi I have a new car with A engine , drilled crank, insert bearings, filter, modified stock pump. Oil press is15 lbs hot cruise speed ,5 lbs idle wondering if this is ok to run till I get diff pump? Thanks
Hayshaker is offline   Reply With Quote
Old 08-31-2013, 11:22 PM   #2
colin1928
colin1928's Avatar
Default Re: New engine
Hello Hayshaker those are good numbers for any A model even for full pressure oil engines I have A and Bs with Full pressure conversion using V8 pumps and modified A pumps and that's about as good as it gets
colin1928 is offline   Reply With Quote
Old 09-01-2013, 08:29 AM   #3
Hayshaker
Thank you Colin I am new to computoring- first try at it. So far so good. Are you aware of the secrets of speed society& their mag?
Old 09-01-2013, 09:22 AM   #4
AL in NY
AL in NY's Avatar
colin1928, I built my own pressurized oil system and my idle oil pressure is 15 lbs and at rpm's above 1000, the the pressure is 35 lbs. In colder weather, the pressure can reach 45 lbs., so 5 and 15 lbs isn't "as good as it gets".
AL in NY
AL in NY is offline   Reply With Quote
Old 09-02-2013, 03:30 AM   #5
colin1928
colin1928's Avatar
AL in NY We all get 45 psi cold
If you are getting 15 psi at 500rpm hot after highway driving say 1 hour
I would like to know your secret
I have spoken with lots of top engine guys who all say hot oil= low pressure in bangers
all of mine have had around 5 psi hot idle and have many hard miles on them
Colin
Old 09-02-2013, 04:42 AM   #6
colin1928
colin1928's Avatar
Hayshaker Yes I know Charlie Yapp and his Mag he knows his stuff
You should also check the guys at F.A.S.T
You can also ask the guys on the hamb about your oil pressure at the monthly banger meet they build and race A/B engines
or any of the engine guys here they are all very helpful
Old 09-02-2013, 09:59 AM   #7
AL in NY
AL in NY's Avatar
colin1928: I do get 15 PSI at 500 RPM's with hot oil. I am running a Stipe oil pump, inline remote mounted full-flow oil filter, 3/8 inch oil from the pump to the oil filter and also 3/8 inch manifold feeding two 1/4 inch and one 5/16 inch oil lines to the mains. My valve chamber pressure relief valve is set to 35 PSI and I have two oil "weep" holes of .055 inches for valve chamber and timing gear oiling. My bearings are AER inserts and I'm running a Swalm's cross drilled and counter weighted crank. My oil pressure will creep above 35 PSI when running above 2500 RPM's. Also, my oil pressure gauge is mounted after the oil filter. I have 3000 miles on this engine configuration and my only problem has been an oil leak from the rear seal. Now you know my "secret".
AL in NY
Old 09-02-2013, 09:59 AM   #8
Jim Brierley
I run modified V8 pumps, and set the regulator at 35 lbs. 5 lbs. at idle is enough. The F.A.S.T. web site is www.hotforhotfours.com I highly recommend taking their magazine.
Jim Brierley is offline   Reply With Quote
Old 09-02-2013, 10:15 AM   #9
pat in Santa Cruz
pat in Santa Cruz's Avatar
I have a modified V8 pump from Stan Vermeil. Around here along the California coast, where temperatures are moderate, oil pressure at idle is 20psi with an engine at operating temp. In Vegas during the heat wave of June, it idled at 5 psi. I set the top oil press at 35. It was at 45, but that caused leakage at the rear main seal.
pat in Santa Cruz is offline   Reply With Quote
Old 09-02-2013, 04:21 PM   #10
Duffy1
So what is the advantage of a pressurized system ?
Duffy1 is offline   Reply With Quote
