Old 01-16-2021, 02:41 PM   #1
Seabees
Default '39 trans to '37 V8?
Howdy boys, I'm wondering if a '39 trans would bolt up to a '37 V8? Not a V8 guy, so I'm lost on this subject. Thanks.
Seabees is offline   Reply With Quote
Old 01-16-2021, 02:51 PM   #2
Hal Beatty
Hal Beatty's Avatar
Default Re: '39 trans to '37 V8?
Yes...
Hal Beatty is offline   Reply With Quote
Old 01-16-2021, 03:00 PM   #3
convert 40
If you have a V8 60 motor, I don't think it will bolt up.
The trans is different and I think the Bell housing and back of block would be different.
convert 40 is offline   Reply With Quote
Old 01-16-2021, 03:05 PM   #4
Brian
Brian's Avatar
Clutch arm may need to be changed to 37 style?
Old 01-16-2021, 04:48 PM   #5
V8COOPMAN
V8COOPMAN's Avatar
Clutch arm needs to match year of car that the trans is mounted in, if all else is stock.
As an aside, back in '64 before I knew any better, I bolted a V8-60 up to the stock trans in my '39 after the 85-horse died. Starter, clutch....everything worked just fine! DD
Click Links Below __
T5 W/TORQUE TUBE
Old 01-16-2021, 04:51 PM   #6
jimTN
Just notch the case to clear starter drive and it works.
Old 01-16-2021, 05:32 PM   #7
ford38v8
ford38v8's Avatar
Can do! The case is the same. Assuming you haven’t got the ‘39 yet, you can gut your own case and replace the innards with the ‘39-‘48 gears, and put on a ‘39 shift tower. Get hold of Mac Van Pelt for the needed parts for the conversion.
PS ~ this is much preferred if your tranny is original to your car, having the serial number that is on your frame and on your title.
Alan
Old 01-16-2021, 08:10 PM   #8
Seabees
Great response from you guys! I am hoping to put the V8 on a Model A frame, and use as much "stock" stuff that I can, for those years. And yes, I'd like to use the mechanical brakes also. I know, I know, I should use juice brakes, but I don't want to, damn it! With Flathead Ted's floaters, I think the brakes will be fine, as long as the are kept adjusted properly. I have them on my Model A pickup and really like how well they work. One other question, how about mounting the V8 in a Model A frame, and use the stock Model A steering box? I've heard there is some adjusting that has to be done in order to miss the left exhaust manifold. Your thoughts please. Thanks guys!
