01-04-2021, 09:11 PM | #1 |
40 ford rear hub sleeves
I Have just pulled down some old stock 40 rear hubs and the outer dia of the hub has lots of pitting ,(water /rust damage from sitting a long time ) is this a sleeve inside there or is it original machined hub surface , Is there a sleeve available to press in and fit smaller od bearings ? or am i up for new hubs
Thanks In advance Phil |
01-04-2021, 10:39 PM | #2 |
Re: 40 ford rear hub sleeves
Sorry, Can't advise you of what to do, but here is a larger picture so other Ford Barners can see the problem easier and offer suggestions. |
01-04-2021, 10:50 PM | #3 |
Well, Does the brake diameter make it worth saving? Nice taper and keyway? Newc
01-04-2021, 11:19 PM | #4 |
Are you sure that's a 40 hub? I thought all hubs 36-48 ran a sleeve 68-1236A with the 68-1225A roller bearing, which is smaller in dia than the earlier style B-1225A roller bearing 28-36, which ran directly in the hub. That hub looks like it's had rollers running directly in it as evidenced by the pattern left in the rust.
01-05-2021, 03:01 AM | #5 |
