Old 09-22-2020, 12:24 PM   #1
roll of the dices
roll of the dices's Avatar
Default Electrical motor to produce vacuum...is there such thing?
As I work on my '30 Ford Roadster, I would like to use the original windshield mounted vacuum powered wiper motor and was wondering if there is such thing as an electrical vacuum source that I can use to feed the wiper motor, instead of using the engine to do so?
I will be running a flathead 59AB motor and I will be running a a 2x2 offenhauser manifold with two 97s. Is there a a source for vacuum on such set up?
No real plans to ever use the wiper, simply looking to have it functional.
Thanks in advance.
...let your brain do the thinking and your fingers do the walking...
roll of the dices is offline   Reply With Quote
Old 09-22-2020, 12:34 PM   #2
Truckerjim
Default Re: Electrical motor to produce vacuum...is there such thing?
Vacuum comes from intake side of engine ,mount a threaded fitting in intake . Then get a vacuum tank and one way valve and mount it so it feeds your wiper , if running six volt might not fin a pump for it .
Truckerjim is offline   Reply With Quote
Old 09-22-2020, 12:50 PM   #3
Floats
Floats's Avatar
Dice roller,
Yep, the aviation industry use vacuum to drive some very important instruments, the artificial horizon, and DI( direction indicator)
They use an engine driven vacuum pump with an instrument panel indication of the ‘vac’ available. I am sure electric pumps are available.
Works well and even the BIG ones use it. But I would not recommend it in your application. Don't reinvent the wheel. It could be done, but why??
Regards,
Chris
Floats is offline   Reply With Quote
Old 09-22-2020, 01:05 PM   #4
DBSHELTON
If using 12v later model Diesel trucks use an electric vacuum pump to operate the A/C and Heater controls.
DBSHELTON is offline   Reply With Quote
Old 09-22-2020, 02:15 PM   #5
1930-Pickup
You can use almost any air compressor, just hook up to the intake side instead.
You'll need to do some fabricating of course.
Don't forget that air compressors and vacuum motors tend to run noisy, unless you use something like a centrifugal pump, but they don't produce much pressure differencial.
To run a vacuum wiper, you'll need a decent pressure differential and some decent volumetric flow. In other words, ya gotta do some math and empirical testing to make it work right.
"That's my wild unsubstantiated guess, and I'm sticking to it regardless of the facts!"
1930-Pickup is offline   Reply With Quote
Old 09-22-2020, 02:42 PM   #6
Bob C
Here you go. https://www.ebay.com/itm/1940s-1950s...Vdl76f&vxp=mtr
Old 09-22-2020, 03:31 PM   #7
Ak Sourdough
Ak Sourdough's Avatar
Perhaps an electric wiper motor would solve the problem.
I still have an excellent rememberer, trouble is my forgetter is so much better that it often overrides the rememberer.
Ak Sourdough is offline   Reply With Quote
Old 09-22-2020, 08:29 PM   #8
dbaldwi3
dbaldwi3's Avatar
Gm used a plastic tank back in the 70’s I believe. It was designed to hold the vacuum when the engine wasn’t producing enough. That’s when they were using vacuum to run all the defrost, inside and outside air doors for the ventilation system. You could try using something along those lines to store the vacuum for the wiper motor and you could hide it under the body no one would be the wiser.
dbaldwi3 is offline   Reply With Quote
Old 09-22-2020, 08:36 PM   #9
McMimmcs
McMimmcs's Avatar
Obviously not worried about judging so your idea makes much more sense !
Old 09-22-2020, 09:16 PM   #10
roll of the dices
Thank you all for your replies
An electrical motor is not really an option. I want the look of the original wiper motor.
I doubt that I will ever use it; however, I would like it to be functional.
Truckerjim got me thinking....I do have a vacuum port at the base of the intake manifold that is currently feeding the advance in the distributor. Can I potentially T off that and feed the wiper motor?
Old 09-22-2020, 09:35 PM   #11
McMimmcs
McMimmcs's Avatar
with a flathead and 2 carburetors I wouldn’t worry about the authentic look of the wiper haha !
Old 09-23-2020, 08:27 AM   #12
Tim Ayers
Later flatheads ('51-'53 I think) had a fuel pump with a vacuum pump on the bottom. Would be a simple swap.
Old 09-23-2020, 09:14 AM   #13
AZ_Nick
On my old old Tudor I ran a small 12V electric vacuum pump from a diesel RV and a reservoir tank. Both lightweight and inexpensive.
AZ_Nick is offline   Reply With Quote
Old 09-23-2020, 09:47 AM   #14
Big hammer
T off and with two using vacuum should work ok, moderns have a t in the intake manifold and several ports, one of the largest user of vacuum is a brake booster, pcv
get a bigger hammer tap done
Old 09-23-2020, 01:11 PM   #15
Y-Blockhead
Y-Blockhead's Avatar
Your vacuum port in the manifold should work OK for the wipers but is probably not the best place for your vacuum advance. Most vacuum advance use "ported vacuum" (vacuum tap above the throttle plates) , not manifold vacuum.
Unfortunately it is very rare to find a Stromberg with vacuum ports. I ran into the same problem with my Y-Block. I have three vacuum taps, Power brake booster, vacuum modulator for trans and vacuum advance.
r
Old 09-23-2020, 02:35 PM   #16
Merc Cruzer
Merc Cruzer's Avatar
Yes, there was period correct 6 volt electric vacuum pump, built by the same manufacture, Trico, of the vacuum wipers. They work great. You might want to read through this post:
https://www.fordbarn.com/forum/showt...=186904&page=3
If you have any questions, feel free to contact me.
Merc Cruzer is offline   Reply With Quote
Old 09-23-2020, 02:52 PM   #17
Kurt in NJ
Kurt in NJ's Avatar
What about drilling the frond manifold riser to match the rear and put a port there
Old 09-24-2020, 01:04 PM   #18
rotorwrench
rotorwrench's Avatar
Dorman makes the 904-214 vacuum pump for a reasonable price. You might check and see if that will work. The one from Jeggs is around $130 so it isn't cheap.
Keep in mind that the standard V8 type generators for the 59 series V8s are only 35 amp capacity. If you run an alternator of 40 amp or better then it shouldn't be an issue.
