01-03-2021, 03:56 PM | #1 |
Brakes Bendix style
Will Speedway Motors Bendix style backing plate kits, fit old 46 brake drums ?
01-03-2021, 04:36 PM | #2 |
Re: Brakes Bendix style
They say that they fit '37-'48 and the front shoes are 12x2
01-03-2021, 04:57 PM | #3 |
Send a PM (Private Message) to FordBarn member "Krylon32". He sells those same backing plates (Speedway's backing plates are produced by MT Products....Speedway's drums are NOT the GOOD quality of MT drums) at a 10% discount to FordBarn folks. You can PM him directly by clicking on the link below.DD
PS....MT Products and "Boling Brothers" is synonymous. https://www.fordbarn.com/forum/priva...o=newpm&u=1914 Last edited by V8COOPMAN; 01-03-2021 at 05:18 PM. |
01-03-2021, 05:07 PM | #4 |
I put a complete set on my '46 Coupe. I got them from Mac's, but check with Boling Brothers, as there may be a price difference. BB has a good web site with info on their products You need to do a bit of grinding on the tops of the front spindles, but other than that, they fit and work well. If I recall, I had to shorten the park brake return spring, as the spring would bottom out before the lever went full travel to put the brakes on.
http://www.bolingbrothers.com/brake-kits-1937-1948/ Last edited by 51woodie; 01-03-2021 at 06:08 PM. |
01-03-2021, 07:25 PM | #5 | |
01-03-2021, 08:56 PM | #6 | |
See, this early in 2021 and I've already blown it. I meant to quote the original poster asking for the info......sorry! DD |
01-04-2021, 08:51 AM | #7 |
Personally I am having a hard time trying to decide if I want the Bendix brakes on front . The disc brake kit from speedway looks super easy to install. I have found the adapter to change the master cylinder from three bolt to two bolt application. Just not sure if I need to change master cylinder or not? Would change rear to bendix brakes for sure.
Understand (i think) the RPV on the front and the APV on rear. |
01-04-2021, 09:37 AM | #8 |
I'm thinking it was the flash of your headlights that temporarily blurred his vision
01-04-2021, 10:50 AM | #9 |
3wmike. If you are going with the Bendix kits, the supplier will need to know the width of the brake shoes. My '46 drums are 1-3/4".
01-04-2021, 11:20 AM | #10 |
Thank You for answers, all of you above, I`ll contact BB
//Mike from Sweden |
01-04-2021, 01:14 PM | #11 |
Mike. Have a good look at the BB site, as they have some tech info and installation instructions on there. You will see in the picture of my left front shoe, what I mean by needing the shoe radius matched to the drums. I arced the shoes, and much better braking performance.
01-04-2021, 01:39 PM | #12 |
I find the third paragraph in the instruction sheet quite interesting.
01-04-2021, 01:43 PM | #13 |
pictures of work need to do to the spindles
01-05-2021, 01:47 PM | #14 |
Thanks
01-05-2021, 02:13 PM | #15 |
Another BB spindle grinding approach. I will mail you a copy of the template, if desired.
01-13-2021, 08:11 AM | #16 |
Krylon32
Hi, I`m interessed in buying a set of brake plates but I can`t send you a PM cause FordBarn said I must have 10 posts, so can you send me a PM with your e-mail adress Thanks Michael |
01-13-2021, 04:34 PM | #17 |
You can catch him at Cornhusker Rod & Custom too.
01-13-2021, 05:10 PM | #18 | |
Gary Mussman 122 Southern Hills • Hebron, NE • 68370. Phone: 402-749-1932 __________________________________________ Gary's "Cornhuskers" web site at the link below! DD http://myflatheadford.com/business-d...d-and-customs/ |
01-17-2021, 01:19 PM | #19 |
Thanks guys, I´ve get in touch with Gary now
01-17-2021, 06:12 PM | #20 | |
Charlie Stephens |
