Old 01-22-2021, 03:29 PM   #21
Ronnieroadster
Ronnieroadster's Avatar
Default Re: ultimate flathead
Boy am I glad the guy never raced at Bonneville with so much horsepower and RPM's from that 239 cube flathead the records would be REALLY high and no one would be able to touch them. LMAO
I use the F word a lot no not that word these words Flathead , Focus and Finish.
"Life Member of the Bonneville 200 MPH Club using a Ford Flathead block"
Owner , Builder, Driver of the First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 in one and a half miles burning gasoline.
First ever gas burning Ford flathead powered roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH
Old 01-22-2021, 03:30 PM   #22
51 MERC-CT
51 MERC-CT's Avatar
Originally Posted by tubman View Post
With that kind of numbers, whether it was or wasn't a 239 is irrelevant.
"Was" as in used to be, but now in pieces
Old 01-22-2021, 04:43 PM   #23
Pete
Pete's Avatar
Getting that kind of RPM's is easy; just use a tachometer for a 4 cylinder engine.
Or with a cable drive tach, use a 1 to 2 drive unit.
Here is a pic of that setup with the tattletale at 9300. Really gets the fans talking after the race. This was a fairly stock 4 banger.
Old 01-22-2021, 07:40 PM   #24
VeryTangled
VeryTangled's Avatar
This is the part of the whimsical story that got my eyes rolling...
"This is a steep hill which goes from sea level to 1500-feet elevation in less than seven miles. I punched the throttle and away we went: 50 mph, then 70 mph, then 90 mph. The numbers stopped at 90 mph but the needle kept climbing around back to 0 again, then 10, 20, and finally 30 mph on the second time around."
-Jeff H
Old 01-22-2021, 07:46 PM   #25
Tim Ayers
Sometime after that I was out to Barger-Mattson wrecking yard and found a blown 350-cid Corvette engine in the inventory. I bought the camshaft, heads, distributor, intake manifold and carburetor and commenced to put them on my engine. What a difference in power that made. It still didn’t match up to the flathead I used to have, but it was about 50 percent better than the stock 283. The only problem was that the carburetor was a 750-cfm Quadrajet and while a 350 might handle that, the 283 would not. I ultimately pulled off the intake manifold and carburetor and put a 4GC Rochester in its place, then everything worked like it was supposed to. Later on, I pulled the manifold off again and put a 2GC Rochester carburetor on it as the 2GC was easier to work on than the 4GC. Since I only drive the ’32 about once a year and I don’t do much hot rodding anymore, that is about all I need. When I put the Chevrolet motor in the ’32, I found that, while the flathead with its high revolutions handled the 4.44 differential OK, the 283 did not so, again, I changed differentials and went back to the 3.78 ratio, which the 283 handles OK.
This story is like a car wreck. I can't stop looking at it. This passage is just too good to not share. Even includes the mandatory bench racing equivalent of the cherry on top: The Corvette SBC. Nothing else will do.
Old 01-22-2021, 08:40 PM   #26
tubman
tubman's Avatar
I have known guys like this. I was trying to buy a 392 Hemi from a guy once. After listening to his BS for about 15 minutes ("the driveshaft was twisted like a barber pole"), I gave up and went home.
Old 01-22-2021, 08:58 PM   #27
Tim Ayers
We have a local guy that we call Shades. He is always wearing Richard Petty type shades. I mean always.
One of my favorite Shades stories is when he was driving his '72 SBC powered Chevelle down Rt. 22 in Easton, PA in a race. At 120, he realized he wasn't in fourth. Once he "slammed it" into fourth, he estimates he topped out at 160.
I guess this BS works on some folks, but to have such a bullsh*t story published in a magazine is a bit surprising.
Old 01-22-2021, 11:28 PM   #28
Scotty's 52 F3
Scotty's 52 F3's Avatar
Just wondering if it was April 1st? I didn't read the story. You guys provided more than enough info for me.
Scotty's 52 F3 is offline   Reply With Quote
Old 01-23-2021, 08:19 AM   #29
corvette8n
corvette8n's Avatar
I read that story and I think he forgot to take his prevagen before he woke up.
Old 01-23-2021, 10:07 AM   #30
Bored&Stroked
Bored&Stroked's Avatar
My guess, made about 120 HP and started seriously wheezing by about 5000 RPM . . .
Old 01-23-2021, 02:24 PM   #31
Flathead
Flathead's Avatar
Just cause it's printed in a magazine doesn't mean it's true.
Flathead is offline   Reply With Quote
Old 01-23-2021, 02:42 PM   #32
Lanny
Lanny's Avatar
If BULLSHIT was Money, then this guy is a Billionaire
If mama ain't happy, ain't nobody happy.
But if daddy ain't happy...RUN
Lanny is offline   Reply With Quote
Old 01-23-2021, 02:55 PM   #33
Holeshot
Haters gonna hate, I guess.
To the youth reading this, always remember that anything is possible.
Heck we even put a man in space only a few years later.
"Sometimes he would accuse chestnuts of being lazy, the sort of general malaise that only the genius possess and the insane lament."
Holeshot is offline   Reply With Quote
Old 01-23-2021, 04:11 PM   #34
V8COOPMAN
V8COOPMAN's Avatar
Yeah, but it damned-sure weren't with no 12,000 RPM flathead! DD
Click Links Below __
T5 W/TORQUE TUBE
Old 01-23-2021, 09:46 PM   #35
Jim Marlett
Our strictly strip flathead hit 6,000 on a good day, but made me nervous. 350hp at 10,000rpm ain't gonna happen with that engine.
Jim Marlett is offline   Reply With Quote
Old 01-23-2021, 10:04 PM   #36
JSeery
JSeery's Avatar
This is just a store in the vain of Paul Bunyan.
Old 01-24-2021, 03:37 AM   #37
aussie merc
aussie merc's Avatar
they dont buildem like that any more
aussie merc is offline   Reply With Quote
Old 01-24-2021, 09:03 AM   #38
Tim Ayers
No hating, but since you brought up the youngsters: Kids, do not try this at home.
Old 01-24-2021, 01:02 PM   #39
Brian
Brian's Avatar
Aw, come on guys, the truth of the matter is that a flathead is superior to a sbc.
Old 01-24-2021, 01:37 PM   #40
Tim Ayers
Now that is the gospel truth!!!!
