01-17-2021, 06:11 PM | #1 |
7 Tooth steering box tip .
There is a quick tip to decrease steering box lash in the dead ahead position . In RHD cars there is good access to the box but in LHD cars the starter motor could present access problems but I dont think so .
Put the steering wheel in the dead ahead position . Remove the Pitman arm . Remove the three bolt triangular cover plate . Depending what lube is in the box watch out for a lube spill and take suitable precautions . Gently tap the sector shaft inwards until the sector clears the worm .Note the sector position keep it like that .Rotate the steering wheel a true half turn and tap the sector back into engagement . Pack the box with whatever lube you prefer and bolt the cover plate back on if the paper gasket is OK if not renew . Replace the Pitman arm .The worm is "double start" and now the sector is meshed with what was the less worn other side of the worm . The trade off is that there will be more lash when the steering wheel is half a turn away from dead ahead but the Ackerman geometry will load against lash so you in practise should not find any difference . I dont think I would be the first to pass this tip on so you might find no improvement this means a previous owner has beaten you to it . In some cases it does remove appreciable ahead lash and it is quick (and cheap) to do !!! John still very locked down in Suffolk County England . Last edited by john charlton; 01-17-2021 at 06:16 PM. |
01-17-2021, 06:44 PM | #2 |
Re: 7 Tooth steering box tip .
Very clever, wish I knew that before I went to an F100 box.
01-17-2021, 08:35 PM | #3 |
Hey John, Great tip. Thanks.
01-17-2021, 08:48 PM | #4 |
Makes sense to me!
BTW, I use eccentric bushes for the sector shaft to get zero play when I assemble a 7 tooth steering box. I think a similar result could be achieved if the bushes could be moved after assembly, but they are not.
01-18-2021, 05:27 AM | #5 |
Hi Synchro ,In the past RHD 7 tooth steering box parts were not available . My local specialist did an exchange service . The sector shaft was turned down to true and an eccentric bush made to suit .This was machined to a slip fit in the housing and rotated to adjust then locked with "Locktite" As RHD parts are now available they do not offer the service anymore as no need .
John in very cold not like you !!! Suffolk County England . |
01-18-2021, 05:02 PM | #6 | |
Your solution would be OK but did it get tight once you were off the straight ahead position?
01-19-2021, 06:29 AM | #7 |
Hi Synchro . On the few I have done they have worked just fine no tightness lock to lock .
John in same weather locked down Suffolk County England . |
01-19-2021, 10:52 PM | #8 |
..... Rotate the steering wheel a true half turn and tap the sector back into engagement......
Does it make any difference which way you turn the steering wheel? |
01-20-2021, 03:48 AM | #9 |
A half turn either way it makes no difference .
John in windy storm "Cristoph" Suffolk County England . |
