Old 09-26-2021, 04:20 PM   #1
Old Redneck
Old Redneck's Avatar
Send a message via AIM to Old Redneck Send a message via Yahoo to Old Redneck
Default Carbon Coil Wire on my 56 T- Bird
My T-Bird started breaking up and kept getting worse as I drive it. It did not act like the carb but electric. A long time age I had a Model A that did the same thing. It drove me up a wall finding what was wrong. A friend ask If I had a Carbon coil wire???? I Took it off and put a steel coil wire solve the problem. I check the coil wire and sure enough CARBON WIRE. I put a steel coil wire and solve most of the problem. I am changing all the spark plugs wire to steel wires. Have any of you ever had this problem?
Old Redneck is offline   Reply With Quote
Old 09-26-2021, 07:33 PM   #2
paul2748
paul2748's Avatar
Default Re: Carbon Coil Wire on my 56 T- Bird
I think you may find radio interference with all steel core wire. The coli wire could have been just a bad wire. I would go with a new carbon coil wire first before changing out all the other wires.
You say that MOST of the problem was solved. It may be that the plug wires on it now are not in the best of shape and need replacement.
I have carbon wires on my 56 with no problems, same with my 54 Ford with a 312 in it.
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 09-26-2021, 08:59 PM   #3
miker98038
miker98038's Avatar
I can almost guaranteed you’ll have interference problems with steel core wires, and running “resistance” plugs if they even still make them didn’t help. I’m running the correct wires from one of the bird suppliers with no problems. Old carbon cores I’d suspect would break down, but the replacements will last for years. That’s with an MSD or other “hot” ignitions with way more voltage. My 55 used a set with a brown coil lead to be correct, not sure about a 56.
miker98038 is offline   Reply With Quote
Old 09-26-2021, 09:38 PM   #4
Crankster
Crankster's Avatar
Carbon core spark plug wires will tend to break down, eventually. Particularly the coil wire, as you've discovered.
"Resistor" plugs are practically the only type available unless you look hard.
Crankster is offline   Reply With Quote
Old 09-27-2021, 06:25 PM   #5
miker98038
miker98038's Avatar
Sorry, I guess I mis spoke. I was referring to those “magic” plugs that were around years ago that were supposed to cure everything. That’s been 50 years now.
Old 10-03-2021, 03:02 AM   #6
KULTULZ
KULTULZ's Avatar
Talking Re: Carbon Coil Wire on my 56 T- Bird
Years ago...
Would put RACING WIRES on an engine and drive through neighborhoods messing up everyone's TV reception.
No, solid cores are for racing only as they can also interfere with electronic ignitions.
As for the BROWN COIL WIRE, it was used from 1954 to 1957 I think (will have to double check) - 8EQ 12298
CASCO makes (offers) a reproduction set with the brown coil wire.
- WHY IS IT ... -
... that everything you buy in the grocery store is either wrapped in or contained in plastic but the government doesn't want you to carry it out in a plastic bag?
WONDERING IN W(BY GOD)V ...
DIAGNOSED CDO - (OCD In Correct Alphabetical Order)
KULTULZ is offline   Reply With Quote
Old 10-03-2021, 06:15 PM   #7
dmsfrr
dmsfrr's Avatar
Originally Posted by KULTULZ View Post
... No, solid cores are for racing only as they can also interfere with electronic ignitions. ...
"Its very important to verify that your spark plug wires are compatible with the ignition system, or any on-board electronics in general. Solid core wires have a copper or stainless steel conductor and generate excessive Electromagnetic Interference (EMI). This EMI can create confusion with electronics and ultimately damage them. With all PerTronix ignitions we recommend that a suppression style spark plug wire (also called carbon core) be used."
https://pertronixbrands.com/pages/fa...ccordion-1-mtf
dmsfrr is offline   Reply With Quote
Old 10-07-2021, 07:34 AM   #8
Old Redneck
I got the correct set of Spark Plug Wires from Hill's.
