07-30-2021, 02:02 PM | #21 |
Re: Finally starting my 35s juice brake conversion
Hey AnthonyG, you can buy 25' rolls of NiCop tubing at places like Jegs.
07-30-2021, 02:26 PM | #22 |
Will original Bearings & Nut fit?
Yes, they will interchange
07-30-2021, 03:18 PM | #23 | |
Bill |
07-30-2021, 04:41 PM | #24 |
Bill's information is correct
07-31-2021, 11:45 AM | #25 |
Or put the nut on backwards! But who would do that?
07-31-2021, 08:40 PM | #26 |
08-02-2021, 03:12 PM | #27 |
I’m using the ‘37-‘41backing plates & rear hubs to use with Lockheed rear brakes. Should I order the seals, bearings, key & snap rings for the ‘37-‘41 & will it fit the ‘35 banjo rear axles?
Nomad |
08-02-2021, 05:07 PM | #28 |
Once again I think Im making it more complicated than it is. In reading threads & asking questions I think Im mixing up what I need for stock Lockheed rear brakes & the The Bendix type conversion. In another thread it was said I could use my 35 drums if not cut over 12.085. As the 35 drum / hub is a pressed swedged assy are they compatible with the later years Lockheed backing plates? I was thinking probably wrongly not & that the 37-41 rear hub needed to be used
Nomad |
08-02-2021, 07:56 PM | #29 | |
Bill |
