Old 03-24-2021, 06:15 AM   #1
danliveshere
danliveshere's Avatar
Default 35/36 16 gal gas tanks
Hi are any of the vendors making 16 gallon gas tanks with the correct threaded fill pipe? Thanks Dan.
danliveshere is offline   Reply With Quote
Old 03-24-2021, 11:25 AM   #2
VeryTangled
VeryTangled's Avatar
Default Re: 35/36 16 gal gas tanks
Hi Everyone. Dan, no and yes. Carpenter makes a tank that physically fits in either 35/36.
My experience was to use an original '35 threaded fuel neck to go in a '35 car to match the fender height where the filler exits. Use a '36 neck (available repro? I got one when I got my tank about three years ago) with a '36 fender which has a different curve profile in that area.
The repro/36 neck on a '35 fender makes the filler sit low at the hole where the filler cap is.
Added: Was just flipping through Don Rogers' '36 book and you might want to look at page 92. A nice pic with some part numbers.
-Jeff H
Have you thought about supporting the Early Ford V-8 Foundation Museum?
VeryTangled is offline   Reply With Quote
Old 03-25-2021, 05:40 AM   #3
danliveshere
Ok thanks Jeff. I have a few original tanks. Looks like I’ll be buying the acid tank treatment. I thought if I could buy the bigger one I’ll get it new.
