03-23-2021, 12:46 PM | #21 | |
Re: Electrical questions from an Idiot
03-23-2021, 12:59 PM | #22 |
Sounds like the same problem I had with my 39. I found I had the wrong solenoid. There is one for a different make that looks the same as the ford one but needs power instead of ground to energize. These types use a 2 wire starter button.
03-23-2021, 01:04 PM | #23 | |
Your sketch looks correct....IF the two big cables are wired to the appropriate posts on solenoid. If the two big wires DO NOT go to the correct posts, it ain;t gonna work. Please go measure for VOLTAGE between the SMALL center post, and GROUND. If you see 6v, you're good. If you see 0 volts, the two big wires are wired backwards. Let's verify that THIS is correct before going any further. DD |
03-23-2021, 01:26 PM | #24 | |
03-23-2021, 03:01 PM | #25 | |
C'mon man.....cut class! Take the rest of the day off. Like Cheech & Chong .....tell the boss you have to REE-PAIR the Jeep! Man, we've gott'a get this thing to crankin'! DD |
03-23-2021, 05:37 PM | #26 |
03-23-2021, 05:49 PM | #27 |
I agree with "cas3". The first thing to do is to determine if you have the proper solenoid for your car.
03-23-2021, 06:32 PM | #28 |
Yep, something is not right, as far as original goes. There are lots of ways to wire things up using various part combinations. But the further you move for the original parts and configuration the more difficult things become unless you really understand what your doing. My suggestion would be to return it to a stock configuration and make life easier! It is a very simple electric system, if it's not modified by someone not understanding what their doing.
03-23-2021, 06:51 PM | #29 |
rock .....This diagram indicates essentially what you SHOULD have, including the POS GROUND set-up. What this drawing DOES NOT necessarily indicate is the PROPER post to wire the CORRECT corresponding large cable to. Wondering if the two large poles on your solenoid might be marked in any way? DD |
03-23-2021, 06:58 PM | #30 |
Some are marked. Think it is normally battery side toward the center of the car and starter on the outside. Some photos would help. What does your solenoid look like? All metal or black plastic?
03-23-2021, 07:16 PM | #31 |
Just went out and checked a couple of solenoids, they were both marked for BAT side. Your solenoid should look something like this.
03-23-2021, 07:27 PM | #32 |
This is how the solenoid is wired internally (an original style). Making a hot connection from the center post of the solenoid to the battery should not work at all, so I would guess the solenoid is not the correct one.
03-24-2021, 08:28 AM | #33 |
There are two types of single control terminal relays. JSeery has explained the Ford type but there are also ones that have no internal connection of the small single terminal to the power side large terminal (Bat). These types have an internal connection of the relay coil to the body of the relay which is grounded when installed on the car. This type has to have a switched power connection to the small terminal in order to energize the relay. This type can have the battery connection and starter connection either way on the large terminals and still function. Ford did NOT use this type. The best way to check either type is with a multi-meter set to read ohms resistance. A volt meter or test light would only work on the Ford type relay when properly connected in the circuit.
Also keep in mind that a relay operating coil has it's own resistance value which is generally a lower value on relays that are for intermittent service like a starter relay since it has larger gauge coil wire with less number of wire turns in the coil. Continuous service relays generally have a higher value of resistance in the operating coil due to smaller gauge wire and a lot more turns of wire in the make up of the coil. This relay type is also known as a holding relay and are more commonly used as a battery relay where they are switched on all the time during operation of the battery system. |
