Old 09-19-2021, 11:50 AM   #1
jbwthree
jbwthree's Avatar
Default ‘30 Tudor Cowl to Chassis Mounts
Hello all. As I go through the list of things to sort out on my ‘30 Tudor, one such item is the body mounting and alignment. The prior owner had the car “restored” by a shop and they apparently neglected this step. The difficult part of that the cowl mounting points are non-existent and need to be fabricated. This would’ve been far easier before they laid down the gorgeous rock moss green paint job. The hood and door misalignment are also doing a number on the paint. So my question here is to find out whether others have dealt with a similar issue. Also, if someone could send a photo of what these mounts are supposed to look like, it would be much appreciated. I’ve got a couple of ideas but none are optimal.
jbwthree is offline   Reply With Quote
Old 09-19-2021, 01:56 PM   #2
Bob C
Default Re: ‘30 Tudor Cowl to Chassis Mounts
Are you saying the frame bracket is missing??
Old 09-19-2021, 03:05 PM   #3
jbwthree
jbwthree's Avatar
Bob - it looks to me like there is a piece of the cowl sheet metal missing. Both sides are similar except that the passengers side has a piece of angle iron there as a half-a$$ed replacement.
Old 09-20-2021, 07:57 AM   #4
Russell Reay
It's hard to say for sure, but I think this is the same area, but with subrail patch panels installed.
Russell Reay is offline   Reply With Quote
