11-28-2023, 02:19 PM | #21 |
Re: 12 conversion
Reading half the real current is fine by me. In some circles, folks say a voltmeter is better for seeing the condition of the charging system anyway.
11-30-2023, 04:56 AM | #22 |
Re: 12 conversion
Thanks so much for the idea of a plug in charger outlet. I did not know that such a thing exists.
11-30-2023, 05:28 AM | #23 |
Re: 12 conversion
Werner, Excellent suggestions.
Grüße aus der südlichen Weinstraße |
11-30-2023, 05:57 AM | #24 |
Re: 12 conversion
With this model of charger, the alligator clips can be removed and the ring lugs connected to the battery. Then the polarized plug at the other end can be routed to the engine compartment for easy access. Found at https://www.batterytender.com/Batter...attery-Charger They have other 6v chargers.
11-30-2023, 07:35 AM | #25 |
Re: 12 conversion
Here is another one for $40.00. I have this brand and have used it for about 15 years.
https://www.cabelas.com/shop/en/schu...77f4e543167c22
Brian SATX |
11-30-2023, 07:35 AM | #26 |
Re: 12 conversion
11-30-2023, 08:11 AM | #27 | |
Re: 12 conversion
12 volt with internal resistor . |
12-02-2023, 05:06 PM | #28 |
Re: 12 conversion
Coils, by their name, already are a resistor of sorts in relation to the primary winding. The 3-Ohm primary type coils are made to work on 12-volts. The 1.3 to 1.5 Ohm ballast resistor or resistance wire is only necessary on a 1.5 Ohm coil being operated on 12-volts. Manufacturers were slow to go to the 3-Ohm coil. The 1.5 was used clear up into the late 60s & early 70s. Electronic ignition systems finally made the manufacturers change.
External ballasts kept the heat on the outside of the old coils. Many had an oil insulator inside that could leak under extreme conditions. Modern coils use a high temp type epoxy resin inside that can take the heat. Last edited by rotorwrench; 12-02-2023 at 05:14 PM. |
12-02-2023, 10:26 PM | #29 |
Re: 12 conversion
The car started just fine in 1929/31 using low octane fuel. and batteries that were probably not as good as what we have now. I show my 1914 Cadillac at the national meet, it starts great on 6 volts on the coldest days in Oklahoma. Spend some time cleaning Conections, scraping paint from the flywheel housing where the starter mounts, and learn how to use an Ohm meter to check for resistance
12-03-2023, 09:49 AM | #30 |
Re: 12 conversion
As posted above, 6 v batteries are harder to find, more expensive, poorer quality, shorter lived, worrisome for some to jump start, etc. in my opinion, at this time, and in my place. Your Mileage May Vary as some say.
When a child, we played "musical chairs", one less chair then the number of players. My wife says i play "musical batteries". The nice cars sit out the salt season. Their batteries age, (despite battery tenders, trickle chargers, and in boat yards, a heated shelf with all the batteries hooked to on central charger). I find it easier to have all the tractors, wood splitters, modern cars, beaters, English cars, and the model A to have the same 12v and neg ground. I have changed batteries since my teenage years to fit the occasion. One, or only a few, commonly found, simply available, Group 25 12v can fit all of the above, with regular use is always pretty well charged, COSTS LESS (important to me), etc. Musical batteries plays much easier if all the players use the same battery. Side note:"Musical License Plates", if played appropriately and safely, works too. I've seen several Model A's with the same serial number stamped on the frame ,right inside the edge of the floorboard. Before I'd pass one of these on to a new owner, of course, I'd wipe that out. A correct number is ,very likely, hidden under the body, if inquiring minds really must know. YMMV. Nothing else to see or say here, let's move along, Russ |
12-03-2023, 11:02 AM | #31 |
Re: 12 conversion
To change the starter over to 12 volts, rewire or replace the field windings. See https://www.snydersantiqueauto.com/p...htm?pid=976153.
You will need a good soldering iron. I have found the Weller brand, the kind with the trigger, works the best. The 6 volt windings are two in parallel and 2 in series. The 12 volt winds are all in series. The screws that hold the magnet poles in place can be removed by using two large C clamps to clamp the poles to the case and take the pressure off the screws. The same procedure is used to put the screws back in.
12-03-2023, 04:17 PM | #32 |
Re: 12 conversion
If you want a good 6 volt battery, go to a farm store.
12-03-2023, 04:59 PM | #33 | |
Re: 12 conversion
In addition, a set of those would cost close to $100 here. My conversion costs me nothing but a little time (and some wire and solder)
12-03-2023, 06:04 PM | #34 |
Re: 12 conversion
If 6 volt batteries ever become unavailable, I might consider changing over, but even in my small city, there are several places to get them.
6 volt cars crank slower than what we are used to in our modern cars, but I have never had it not start. The exception was when I left my lights on and drained the battery, which would also happen with 12 volts. I am perfectly good with leaving something that has worked reliably for 94 years in place. For charging, rather than pulling the floor board, just lift the hood and connect the positive (red) charger cable to something grounded such as a head nut, and connect the negative (black) cable to the nut on top of the starter where the cable connects that comes directly from the battery. Very easy. So, I am leaving well enough alone. |
