Old 03-23-2024, 10:57 AM   #1
terry
Default KR Wilson tools
I've had these tools for years and never used them. Before I put them on the Swap Meet, could someone tell me what the tool on the right is used for? The left one says "flywheel bearing puller." The right one only gives this info: V176.
Thanks. terry
terry is offline   Reply With Quote
Old 03-23-2024, 11:47 AM   #2
petehoovie
petehoovie's Avatar
Default Re: KR Wilson tools
Thanks. terry
The only thing nice about being imperfect is the joy it brings to others....
"Silver rings, your butt! Them's washers!"
"We shot our way out of that town for a dollar's worth of steel holes!" - from 'The Wild Bunch' - 1969
https://www.youtube.com/watch?v=7NReUd2_0u0
Old 03-23-2024, 11:56 AM   #3
Tim Ayers
Can you list their part numbers? Should be casting into the tool's body somewhere.
Old 03-23-2024, 12:09 PM   #4
Kube
Kube's Avatar
THE v176 IS FOR REMOVING TIE ROD ENDS. THERE ARE NICE AS THEY DON'T DESTROY A TIE ROD END LIKE A "PICKLE FORK" TYPICALLY DOES.
MOSTLY A KRW COLLECTOR ITEM THESE DAYS AS MODERN TIE ROD END REMOVAL TOOLS ARE READILY AVAILABLE, CHEAP AND SMALLER THAN THE OLD KRW VARIATION.
Old 03-23-2024, 12:16 PM   #5
terry
Thanks, Kube. Tim even though I now have the answer, on the bottom is this:3230-N
Old 03-23-2024, 12:16 PM   #6
Kube
Kube's Avatar
The one on the left is a a375a, well, half of the set anyway. This half of the set removes the flywheel bearing. Another tool that is more valuable to a krw collector than a mechanice. Those bearings ae fairly easy to remove without a specilized tool.
