Old 10-27-2020, 11:29 AM   #1
Brian's Dad
Default Model B Fuel Pump
Hi, is it possible to run the stock B fuel pump with any kind of full flow oil filter ?
Brian's Dad is offline   Reply With Quote
Old 10-27-2020, 11:47 AM   #2
alexiskai
alexiskai's Avatar
Default Re: Model B Fuel Pump
Am I correct that you see the two components as incompatible because they typically occupy the same physical space?
Old 10-27-2020, 12:01 PM   #3
ryanheacox
ryanheacox's Avatar
My guess is no although you could probably install a remote filter kit. Or make your own like one member did on here. I think it was Al in NY?
ryanheacox is offline   Reply With Quote
Old 10-27-2020, 12:11 PM   #4
alexiskai
alexiskai's Avatar
Maybe the Stipe adapter? Shows as out of stock, but you could call and see what the situation is.
https://www.specialtymotorcams.com/d...er-prelief-017
Old 10-27-2020, 04:15 PM   #5
Fourd
Fourd's Avatar
I have the Specialty Motor Cams Oil Filter Kit for B and run the stock B pump. It is very well made.
Fourd is offline   Reply With Quote
Old 10-27-2020, 06:40 PM   #6
Benson
Benson's Avatar
I have two Stipe ( Specialty Motor Cams) Model B filter Kits.
Other manufacturers of filter kits make use of the unused fuel pump opening on side of B block to return the oil to the oil pan from an external mounted oil filter.
In these cases you can not run a stock B fuel pump with this oil filter.
Benson is offline   Reply With Quote
Old 10-27-2020, 10:10 PM   #7
CarlG
CarlG's Avatar
My remote full flow oil filter dumps the filtered oil into the valve chamber.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 10-28-2020, 08:27 AM   #8
Benson
Benson's Avatar
Originally Posted by CarlG View Post
The remote full flow oil filter dumps the filtered oil into the valve chamber.
This is filter I spoke about in previous post for Model B which uses (that is covers up) the fuel pump "port" to mount filter.
Looks maybe home brew.
Also has bypass valve that dumps to timing cover.
Filtered Pressure oil goes into stock Model B engine "oil Galley".
Old 10-28-2020, 09:39 AM   #9
katy
katy's Avatar
I would think that the side cover mounted filter should work on a B.
https://www.snydersantiqueauto.com/P...earchByKeyword
