12-13-2020, 05:03 PM | #1 |
headlight current tied to ignition switch?
Is there any SIMPLE way to run the headlights ONLY when the ignition switch is ON? I say SIMPLE because my electrical skills suck.
Thanks |
12-13-2020, 05:10 PM | #2 |
Re: headlight current tied to ignition switch?
12-13-2020, 05:15 PM | #3 |
Hook the ignition to the headlights
12-13-2020, 05:26 PM | #4 |
Sure it can be done, but, not too easily. Its much easier to make sure the light switch is at 6:00 and look at the ammeter.
Part of my post-flight mental checklist is to lastly glance at the ammeter. |
12-13-2020, 07:14 PM | #5 |
If your electrical skills suck, probably no...
That Henry chose to put the ignition switch on the wrong side of the coil (points versus source) it's even more of a pain.
Building a '29 Speedster, the hard way... |
12-13-2020, 07:16 PM | #6 |
12-13-2020, 07:57 PM | #7 |
Bob, I just want to stop leaving the headlights on when I shut off the engine after a drive. I'm getting better at checking the headlight switch, but if I could easily arrange a cutoff of the headlight via the ignition, I'd set it up.....
Thanks all for the input! |
12-13-2020, 08:20 PM | #8 |
Sounds like a job for a 20A rated relay that would close with 6V. If that sentence scares you then it's not easy enough. Or find a friend.
12-13-2020, 08:25 PM | #9 |
If using an original pop-out ignition switch, then NO.
If using a simple off-on ignition switch, it "could" be done, but would require re-wiring the ignition circuit. A concern that I would have is the wire gauge and current you would be running through the ignition switch. With original wiring, the ignition switch only sees about 4 amps. Re-wired to support running lights plus ignition, it could see 15+ amps. |
12-13-2020, 08:28 PM | #10 |
Your best bet is to just look at the switch when turning the car off. Post a note on the dash till you get into the habit.
12-13-2020, 08:55 PM | #11 |
Would something like this help?
https://www.napaonline.com/en/p/GRO8...SABEgJPU_D_BwE It’s not a bad idea to shut off all the current on 90 year old wiring when you aren’t using the car anyway. Sent from my iPhone using Tapatalk |
12-13-2020, 09:19 PM | #12 |
I had this problem and I put in a buzzer that will let me know when the lights are on and my door is open. Been workin good for a long time.
Here is the video. https://youtu.be/it7C06vanBs |
12-13-2020, 09:35 PM | #13 |
I hooked up my dash light to the wire going to the tail light. Now if the parking lights or headlights are still on when I turn the key off I got a visual reminder. No goofs since I did this.
12-14-2020, 05:41 AM | #14 |
Did you put a diode in the line? Otherwise, that might light your tail lights any time the dash light is on.
12-14-2020, 06:49 AM | #15 |
Lots of good ideas. The tail light-dash light idea sounds about my level...
Thanks all. |
12-14-2020, 07:41 AM | #16 |
12-14-2020, 08:56 AM | #17 |
12-14-2020, 09:19 AM | #18 |
I use the electrical cut-out mentioned above. Then in case I forget that I've got in the habit of tapping the horn button when I get out of the vehicle.
12-14-2020, 09:30 AM | #19 |
Where did you put the battery cut-out switch?
I don't like drilling metal and on the wood floor I'd kick it. |
12-14-2020, 10:59 AM | #20 |
Ditto on Curtis' question. Where? I've got a Tudor, so under the driver seat floorboard might make sense.....
