02-18-2016, 04:16 PM | #1 |
Is this 59A flathead part available?
I own a 1940 Ford tudor with a C59A motor.
On the Clutch side of the block, there is a “cup” that accepts the starter shaft as it engages the flywheel. Is this “cup” available as a separate part? Mine has been worn through in the area closest to the ground (likely from too many unpaved Canadian roads). No parts catalogue I've seen shows it as a separate part. Bob Drake's response was that it is not available as a replacement. Do I need to find a dead block and remove it, (unlikely since the availability of parts here is pretty slim), or has someone out there have one that they smartly knocked out as insurance? |
