06-05-2014, 03:28 PM | #1 |
aluminum fan 2 blade
Has anybody replace water pump,and replaced the fan with a new aluminum type fan.hows it working and is it keeping the engine cool.i need some expert advice from you guys.thank you
06-05-2014, 04:27 PM | #2 | |
Re: aluminum fan 2 blade
I did not replace water pump but bought a rebuild kit stainless steel shaft and have no change in operating tempertures. fredski |
06-05-2014, 04:33 PM | #3 |
Bought Mike's leak less pump and fan. Had them prefit because the first pump shaft had been miss drilled.
Can replace fan without pulling radiator.
20 years ago we had Johnny Cash, Steve Jobs, and Bob Hope. Now we have no Cash, no Jobs, and no Hope...please don't let Kevin Bacon die! |
06-05-2014, 07:48 PM | #4 |
I have them on all my Model As. They're great.
06-05-2014, 11:05 PM | #5 |
Yup, rebuilt my fan and use an aluminum fan with great success.
06-06-2014, 12:00 AM | #6 |
06-06-2014, 12:53 AM | #7 |
I recommend you install the collar with an allan set screw and a nylon washer on the front of the waterpump to lock the shaft. It will be hidden under the new aluminum fan. out of sight of any nit picker.
06-06-2014, 07:06 AM | #8 | |
Some guys retard the spark for a slow idle and this will produce excess heat. With a stock head I would have the spark lever half down at idle, which is 20*. |
06-06-2014, 08:31 AM | #9 |
I replaced my pump and fan last year. No issues other than I had to grind a little on the nose of the replacement pump as the fan was rubbing on it.
1929 Model A Barn find. California car, just a few more parts to find. Interior, steering box (rebuild), and I am sure much more! |
