07-06-2012, 06:50 AM | #1 |
Two Thumbs Up for Snyder's Aluminum Fan
I did a post on the aluminum fan a couple years ago, but a search didn't turn it up. A couple years ago I was sent 2 aluminum fans to check for balance. The balance was so good I didn't want to touch it. I also checked the blades for pitch, equal length, straightness, and leading edge of one being parallel to the other and found them both to be excellent.
The other day I was sent another aluminum fan to check for balance. Again I checked the taper fit to the water pump shaft, keyway depth, blade straightness, blade pitch, blade length, and parallelism, and it was excellent it every reguard. These are a vast improvement over what I was seeing about 5 or 6 years ago. For anyone affraid of running an original steel fan, I would recommend this aluminum fan. A thin steel washer should be used under the castle nut when you install the aluminum fan. |
07-06-2012, 09:42 AM | #2 |
Re: Two Thumbs Up for Snyder's Aluminum Fan
Is this fan sold by the other vendors,, or,, is it something different thats made just for Snyders ??
07-06-2012, 09:56 AM | #3 |
07-06-2012, 02:05 PM | #4 |
Thanks..
07-06-2012, 03:09 PM | #5 |
I have to agree. It's a terrific fan. I replaced my cracked steel fan a few years ago and replaced it with the aluminum fan.
Rog |
07-08-2012, 09:15 PM | #6 |
07-08-2012, 10:29 PM | #7 | |
07-09-2012, 01:24 AM | #8 |
Thank you for sharing
For sure, first choice! Tried to order that a year ago, but sadly it was not available at that time. I had to switch to that black-plastic fan. As its 6 blades are smaller in diameter, its mostly hidden and nobody detected it to be plastic since. Even i dont like plastic in my car, i will stick to it. |
07-12-2012, 10:09 AM | #9 |
Thanks a lot for the great info Tom, I will be buying one shortly for testing purposes, Kev.
07-14-2012, 12:48 PM | #10 | |
Why do they keep changing the numbering system on tires and belts? It used to be easy to remember B44 if you wanted a 5/8" x 44" belt, but now I've seen different numbering systems used as well, so best to carry in your old belt to be sure. |
07-14-2012, 03:17 PM | #11 |
I balanced the new Snyder fan (it was off some) then lapped it to the pump shaft ( it was also off a little). Peace of mind.
I had restored a '46 Ford a few years ago and threw a fan blade through the engine compartment and down onto the ground while on a tour. Check any kind of fan. Art |
07-14-2012, 06:04 PM | #12 |
Art, what's a little?
Larry |
