08-22-2020, 10:39 AM | #1 |
35 Ford Ammeter Flops to Full Discharge
Stock 35 Ford, 6 volt. Ammeter started instantly flopping to full discharge (-) when ignition turned on. Car cranks, starts OK & when engine running ammeter indication normal, charging.
What's going on? Thanks. |
08-22-2020, 01:25 PM | #2 |
Re: 35 Ford Ammeter Flops to Full Discharge
Sounds like the cutout is stuck shut
08-22-2020, 02:51 PM | #3 |
Looking at the wiring diagram the only thing the ignition switch supplies
is the coil and oil pressure gauge. |
08-22-2020, 02:53 PM | #4 |
!!! DISCONNECT THE BATTERY A S A P....I have lost 2 1932 AMP METERS AS i WATCHED THE GAGE MELT OUT OF THE GAGE when the points stuck on the cut out ! JME kerk could start a fire possibly
08-22-2020, 03:28 PM | #5 |
