09-18-2023, 09:51 AM | #1 |
1940 ford flathead
Hi i'm new to this so I hope I can do things right. I have a 40 woodie and it starts and runs fine untill I try to drive it. Frist gear is fine but when I go to second it starts to miss fire and I have a hard time getting back to the shop. Not sure what is happening Any info would be great thanks
09-18-2023, 10:03 AM | #2 |
Re: 1940 ford flathead
Start at the distributor. Timing, points, vacuum brake, plug wires and plugs.
After all that’s verified and it’s still doing it then change the coil.
I am building a 1939 1 ton express |
09-18-2023, 10:38 AM | #3 |
Welcome to FordBarn. Hope we can help you.
I think your problem could be so many different things that any of us posting a possible cause would just be guessing. I would suggest you start with the basic diagnosis to at least determine if it is a fuel problem or a spark problem: When it acts up, look down into the carburetor while moving the throttle arm. You should see two squirts of gas. If no squirt, indicates a fuel delivery problem. When it acts up, while idling or cranking with starter, use a pliers to hold a spark plug wire about 1/2" from engine. Should see a blue spark that can jump about 1/2". If not, indicates a problem somewhere in the ignition syatem. |
09-18-2023, 11:15 AM | #4 |
Sound like a classic condenser/coil problem to me.
09-18-2023, 12:33 PM | #5 | |
I agree with Tubman, condenser or coil. If you stop and put it back in first gear, does it run okay until you shift to second? Welcome to the Barn. Last edited by Zeke3; 09-18-2023 at 12:34 PM. Reason: Spelling |
09-18-2023, 01:13 PM | #6 |
09-18-2023, 02:07 PM | #7 |
Could be a crack in the rotor and arcing to the shaft.
09-18-2023, 02:29 PM | #8 |
Has your carb been cleaned real good, are you using ethanol fuel and good power valve installed?
09-18-2023, 03:53 PM | #9 |
Zeke X 2
09-18-2023, 03:54 PM | #10 |
Also dont lean against the fender
09-18-2023, 06:31 PM | #11 |
09-18-2023, 06:51 PM | #12 |
The spark intensity requirement goes up with engine load. You can get away with a weak spark when free revving an engine. You need a bit better spark to pull first gear. You need an ok spark to pull second gear. You need a good spark to go down the freeway in high.
09-18-2023, 07:57 PM | #13 |
Couldn't have said it better myself.
09-18-2023, 11:42 PM | #14 |
Makes sense. Thanks.
