07-18-2023, 02:59 PM | #1 |
35-36 windshield regulator oddity
This is the first time I have seen the small mounting fastener holes. Was this for a certain application?
07-18-2023, 03:10 PM | #2 |
Re: 35-36 windshield regulator oddity
09-20-2023, 08:40 AM | #3 |
I just replaced the windshield frame and glass on my '36 5 window. It also has the small hole crank assembly. Not sure if it's an original piece, but the threaded hole in the body where it mounts is 1/4-20 and everything lines right up.
I actually wanted to remove the regulator to inspect it, but after about a half hour trying to get it out of the small opening I gave up. What do you have to do to get it out, loosen the dash? |
09-20-2023, 10:02 AM | #4 |
Dash should be out to remove it.
09-20-2023, 11:44 AM | #5 | |
