Old 09-17-2019, 08:05 AM   #1
31coupedx
Default 30-31 Model A Wheels
Are the new aftermarket model a wheels made better or worse than the originals. Can you tell the difference between the new ones originals.
Is there someone that is selling original wheel the are not pitted and bent. maybe recondition ones.
31coupedx is offline   Reply With Quote
Old 09-17-2019, 11:10 AM   #2
duke36
Default Re: 30-31 Model A Wheels
The spoke connection profiles at the outer rim are different on the repro's from the originals.
Old 09-18-2019, 11:38 AM   #3
Purdy Swoft
Purdy Swoft's Avatar
Berts model A in Denver usually has good original wheels . I bought the wheels that are on my 31 tudor from Berts and they were perfect .
Old 09-18-2019, 02:27 PM   #4
Mike Peters
Mike Peters's Avatar
I've never been to a parts swap that didn't have some Model A wheels. Easy to find.
Usually cheap, but you don't know if they run true or not.
Mike Peters is offline   Reply With Quote
