Old 09-13-2021, 03:56 PM   #1
Ramblin Reck
Ramblin Reck's Avatar
Default 39 Ford Convertible Door Garnish
39 Ford Convertible Door Garnish OR Garnishment
Seem to be having a hard time finding these parts. All I really need is the passenger side door garnish. Have one for the drivers door. All it is is a fancy piece of sheet metal. The one I have is missing a plate of some kind which probably said Ford or Deluxe right in the middle
Are there huge differences between the 1939 and 1940 Convertibles on the inside of the door.?
Also need instructions again on how to upload pictures
THANKS
Ramblin Reck is offline   Reply With Quote
Old 09-13-2021, 04:36 PM   #2
Kube
Kube's Avatar
Default Re: 39 Ford Convertible Door Garnish
I don't have any decent photos of a '39 molding.
I have attached a photo of the proper '40 moldings. If your molding is missing a plate of some kind, you don't have the correct molding.
If my memory serves me well, the biggest difference between the '39 and '40 moldings are finish and location of mounting holes. Both things easy to modify for your '40.
Old 09-13-2021, 04:55 PM   #3
mercman from oz
mercman from oz's Avatar
photo of the proper '40 moldings by "kube"
Old 09-13-2021, 06:56 PM   #4
swoopNZ
MEMBER EMERITUS
I have one left over from a 39 convertible coupe restoration that I never finished.
They do not have a plate in the middle.
$150 includes shipping from New Zealand.
Chris.NZ.
email me if you are interested.
[email protected]
swoopNZ is offline   Reply With Quote
Old 09-13-2021, 07:12 PM   #5
Karl Wescott
Karl Wescott's Avatar
To take this thread a little off track, the convertible 1940 molding has a small relief (about 1/32") where it butts up against the vent window assembly that of course the 1939 does not. Not sure of the mounting screw location but we have sold fiberglass versions for both applications.
1938 had a rectangular plastic inlay insert in the molding, deluxe only (remember "plastic" was cutting edge high tech in 1938) Carpenter makes the inserts.
Karl Wescott is offline   Reply With Quote
Old 09-13-2021, 11:01 PM   #6
swoopNZ
MEMBER EMERITUS
Sounds like he has a 38 one.
Old 09-14-2021, 01:03 AM   #7
ford38v8
ford38v8's Avatar
His avatar is a 39, but you’re right, he may have one 38 garnish molding and thinking it’s correct fir his 39.
Alan
Old 09-14-2021, 08:28 AM   #8
Ramblin Reck
Many thanks. I think y'all are correct that mine is a 38 Garnish. Good to know that a 38 or 40 Garnish could work. Thanks everyone
Old 09-14-2021, 10:27 AM   #9
Karl Wescott
Just to be clear, a 1940 might work, if one existed, as there was not a convertible sedan in the Ford model lineup.
